Question about Garden
Hi there, Just wondering if you would be able to help me. I was using my 4-stroke ride on lawn mower today through some really long grass. It turned off, and wouldn't start again. The engine is turning over but not starting. It has a brand new battery and the spark plug seems fine. Any idea's? thanks. harry.
    Sergeant:
    Champion:
  • 250 Answers
I would first check for spark by removing the sparkplug, put the wire back on it and ground the nut part on metal part of the engine and have someone turn the key. You should have spark between the gap of the sparkplug. If you are getting good spark take a straw and put it in a cup of gasoline then hold your finger over the top hole and put the end of the straw in the spark plug hole and release your finger from the top of the straw. Do that a few times, put the plug back in and connect the wire. Turn the engine over and if it tries to start you have a fuel problem. If it does not do anything you have to check the engine for compression whith a compression gauge.
Posted on Mar 15, 2011
My z5426 has allways left grass behind,i have to cut my lawn twice
Are your blades sharp? Are they lined up so they do not leave grass in between them as they spin?
Is your cutting deck level or is one side higher than the other.
These are all things that could cause long grass to remain.
Some times a bent blade will do this also.
I even had a lawn mower come in and the blades were installed up side down. He wondered why it would not cut right.
Aug 20, 2016 | Husqvarna Zero Turn Mower Z5426
Engine runs rough under load
how old is the motor
4 stroke with valves or a two stroke ?
blades
spark plug , coil , air fuel mix check valves
re check governor setting
if grass is way above the front height of the frame it will struggle
raise the height first to max on the first run
then lower
or use a grass trimmer to knock the level down before mowing
May 17, 2016 | Garden
Looking for catcher to fit
Instead suggest a mulching blade.
Check to see that the earthworm population in your lawn is healthy.
They will eat the clippings and create castings fertilizer for your lawn.
Most earthworms come out at midnight to feed.
Feb 17, 2016 | Garden
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Wheres the oil drain plug for model 7021 CH1
Most horizontal 4 stroke engines have them on the bottom next to the crank/output shaft that the blade rides on. Tip the mower on it's side and look under it. You should be able to see the bottom of the engine. If it's full of grass/dirt, brush it off. You should see the drain plug.
Apr 30, 2010 | Husqvarna Rear Propelled Rear Bag Lawn...
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
Aug 11, 2009 | Black & Decker Black and Decker Mm575 18"...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
