Question about HP Audio Players & Recorders
I have no sound on my computer through my spakers, they are hooked to my computer but no sound is coming out the speakers at all, they are hp speakers,
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 15, 2011
Ibastek manual
Your Ibastek speaker may be in a sealed enclosure. Many of the small ones are accessible only through the front grille.
Jul 01, 2014 | Infinity Speakers Infinity 629I 225W 2-Way...
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
I am gettting sound through my headphones but not my speakers why?
Normally when you plug in the headphones, the plug turns off the speakers.
Power for the speakers come from the amp to the plug ... there is a switch that opens when you insert the plug. Makes sense in 99% of the cases if you think about it. Why do you need the spakers if you have headphones on?
May 16, 2010 | Logitech X-530 Computer Speakers
What is the problem with my computer sound device even my speaker is alright, how to fix?
fristly reinstall the driver of sound and restart the computer after that the problem is running you cable between spaker to cpu is faulty then replace the cable it will work well
Apr 09, 2010 | Altec Lansing BX1020 Computer Speakers
No sound from headset
MUTE THE SPAKER SOUND AND ADJUST THE SOUND SETTING FOR HEADSET
Jan 26, 2009 | Audio Players & Recorders
HOW DO I CONNAT SEAKER
I think the issue is how to connect the speakers.
The desktop tower will have the three ports behing it.
The colours would be pink, green and blue.
You should be having three holes in the spaker box.
One says IN - a cable should connect the 'IN'  of the speaker box to the green hold in the tower which is the output for the sound from the computer.
The speaker box should be having the other hole named as 'OUT'
Connct the spaker cable to this which is the output of the sound from the speaker box or audio box.
Now enjoy your music from the speakers.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Computers & Internet
Sound problem
check if the spakers are turn on. check in the menu on sound
Apr 28, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
Can I hook up dell speakers to a HP
i think your have problem with sound card,
otherwise dell peakers works with hp.
you should see for updated driver for your sound card.
Oct 31, 2007 | HP P5302M Computer Speakers
One speaker
the reason would be. 1.the spaker coil is open. 2. the speaker connection to the wire may be dry solder.
Sep 30, 2007 | Altec Lansing VS4121 Speaker
54 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
