Question about DCS Double 30'' Grill Cart Side Burners in LP or NG - BGB132- Cooktop
Side burner on Jennaire grill
Works well but produces soot on pans, etc. Not sure if the flame is uneven since the sooting occurs on just one area. How do I remedy this?
  • 59 Answers
Hello
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Posted on Aug 02, 2008
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
I have a new gas hob which is making the bottom of my pans black like soot?
You must have an improper air/gas ratio. To adjust the shutters you simply open or close them a hair till you get a beautiful blue flame. Improper flame is yellow, good flame is blue. 9916a1c.jpgThis gas conversion training manual shows where to adjust
Apr 22, 2010 | Cooktops
High flame
make sure the unit has been converted to propane they are naturally set for natural gas from the factory
Apr 04, 2010 | Cooktops
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
Dec 14, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
DCS Double 30'' Grill Cart Side Burners in LP or NG - BGB132- Cooktop Logo
266 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
