CAN YOU TELL ME WHAT IS THE SPECIFICATIONS OF THE MEMORY? THE SPEED AND SIZE AND WHAT ARE THE THINGS TO CONSIDER?
    President:
  • 2,678 Answers
In simple terms no. Things to consider:- TURN OFF CAPS LOCK!
Spec of the memory in what?
Speed and size of what?
How long is a piece of string?
Posted on Mar 15, 2011
  • DocLove Mar 16, 2011
    CAN'T HELP BUT THANKS
Why won't computer recognize ram
Does the RAM work in a different computer?
Specifications for the RAM?
Size of RAM?
Speed?
Number of chips per side?
Single-sided or double-sided?
Specifications for the motherboard?
Maximum memory-size per stick of RAM that the motherboard supports?
Jul 08, 2014 | Compaq Presario 2100 and 2500 ,NX 9000...
Does this have a 3.0 usb port?
Memory Module Specifications Total Memory Size 6GB Memory Type DDR3 Monitor Specifications Display Type Active Matrix TFT Color LCD Screen Size Connection Type HDMI Maximum Resolution Touch Screen No Media Ports LAN Ports 1 - RJ-45 Ethernet Connector USB Ports (Total) 4
USB Ports Powered (Included In Total) 2x USB 2.0, 2x USB 3.0
Audio Out Jacks Processor Specifications Processor Brand AMD Processor Class A6 Processor Number 5200
Processor Speed 2 GHz Hard Disk Drive Specifications Hard Drives Included Capacity Interface ATA Hard Drive Types Hard Disk Drive
Apr 26, 2014 | Acer Aspire Z Series All-in-one Touch PC...
Does 1rx8 ram go along with 2rx8?
Look at your motherboard manual, it tells you what kind of memory, which slots to use for number of sticks.
Your statement makes no sense, 1r, what is this ?
There is speed and size of memory.
DDR-, DDR 2 or DDR3, then speed, DDR3 2000 which each speed has a corresponding number.
DDR3 2000 is called ( PC3 16000 )
The chipset of the motherboard dictates what size and speed of memory that it can use.
Dec 05, 2012 | Biostar Computers & Internet
Untold probs with connection speed. The only thing that does any good is a factory reset. My isp (talktalk) have identified and sorted a line problem but I was still getting poor (.18mb) download speed...
If the line issue doesn't fix the connectino problem, try considering the specification of your computer. The one that you should be looking for is the RAM value of your computer. if it using lower then 1gb, try updating the memory on the computer. you can also try to use other avaialable browsers like firefox, or google chrome.
Cheers!!
Sep 02, 2010 | Computers & Internet
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
Please let me know things in concern before buying a video card
Mostly goes of your motherboard or budget
Does your motherboard have a AGP or PCI-E slot?
Like you said, power connector if you decide to go for 1 of the top cards that require power, most just require the molex power connection but you might have up upgrade your power supply to use 1 of the newer cards
Apr 28, 2009 | HP PAVILLION DV6841TX PC Desktop
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Unable to upgrade RAM......
Sounds like they are 2 significantly different speed memory sticks. Normally, the faster of the two sticks will "clock down" to match the slower stick.
Without knowing the motherboard and memory stick specifications, it's hard to tell, but it's most likely a speed issue.
Feb 11, 2008 | Computers & Internet
Problems with ga-6veml ram
Hi Luisfe, Your motherboard will only support a maximum of 1GB DRAM and only supports 168 pin, PC-100 or PC-133 SDRAM and VCM SDRAM at 3.3 volts. As long as your modules meet these requirements they should work. Specifically what size and specification modules are you inserting in your two memory sockets? Also when you power up with these modules installed you mentioned you hear beeping. These are *beep error codes*, if you tell us what combination of short and long beeps you hear that will probably help the diagnosis. Once I receive this information I?ll try to help you figure out what?s going on.
Jan 08, 2007 | Gigabyte GA-6VEML Motherboard
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
