Question about Bosch WVTI 3240 Front Load All-in-One Washer / Dryer
How do I rectify e6 error on bosh classixx front loader
    Brigadier General:
  • 6,277 Answers
'e^' means 'no water out' i.e. it isn't able to drain (all of) the water.
I would suggest as a first step that you clean the drain motor lint tray/filter and then the operation of the motor.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 15, 2011
E6 error will not wa what is an e6 error Lg top loader
Check out this website as it may help you.
The Fault has something to do the drive system of the washer. Different model however should be the same. LG WT4870CW error code E6 The Laundry Appliance Repair Forum
Nov 15, 2015 | LG WT5101H Top Load Washer
Error E6
kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you have a nice day
May 04, 2009 | Exercise & Fitness
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Feb 26, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Hi, I have Front loading BOSH Classixx 5 washing machine purchased last week. But i dont have operating instructions in English. I need operating manual of this washing machine in english. Kamalnish
simply go back to the shop it was bought in and they have to supply with the instructions in english at your request at no further charge,email bosh at there customer services they will gladly supply you free of charg.adrian
Jan 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
EO4 POPS UP ON MY bOSH FRONT LOADER WFMC33O1UC
I had error code E06 come up on my Bosch Washing machine and since cleaning out the pipe as suggested, turning the machine back on to run a wash, error code E04 has now popped up...please advise asap what's the best thing for me to do...many thanks :)
Dec 05, 2008 | Washing Machines
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch WVTI 3240 Front Load All-in-One Washer / Dryer Logo
2,159 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
