Question about Polaroid FLM-323B Television
Bad power supply?
Set goes from red to blue on the light and no pics or sound have to unplug to turn off can you help?
    Problem Solver:
  • 5 Answers
Whats the exact model #? You would probably need to send me the power supply.
Posted on Aug 01, 2008
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Nov 28, 2009 | Polaroid FLM-323B Television
My tv does not turn on
This problem is likely a failed power supply. This is a known issue with this model TV. It will normally occur soon after the warrenty expires. It can also be caused by a voltage surge produced by a power failure. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 08, 2009 | Akai LCT2721AD 27 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Insignia lcd tv 32"
have good tec replace if nessary, The inverter module
Mar 03, 2007 | Insignia IS-LCDTV32 32 in. Television
Polaroid FLM-323B Television Logo
50 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
