Question about Brother GX-6750 Typewriter
WHEN I TYPE SOME THING AND HIT THE SPACE BAR THE RETURN BAR IT TYPE ON THE SAME LINE AND EVERY THING IS IN ONE .
  • Brother Master
  • 3,594 Answers
If the paper will move up with the platen knob the paper feed motor probably has a broken plastic gear. The gear and motor are sold as one 35.00.
DickyO
Posted on Mar 15, 2011
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Verify internet connection-not connecting
reset the router by holding in the reset button for 15 to 20 seconds, then wait for all lights to return. If you have DSL wait for the dsl light to be on solid, once thats complete if your using vista and still unable to connect run "diagnose and repair". If after that your still unable to connect, open "run" type "cmd" and hit enter....the type "ipconfig" and hit enter, you should get an ip address, subnet and default gateway. one at a time type "ping" hit space bar 1 time then type the ip address in as shown in the list and hit enter, if 4 return then ping the default gateway, if it returns 4 then ping www.yahoo.com, if return 4 then remove Norton or Mcafee from your system and try again.
Feb 19, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Tab and return
reset the left margin at 69, or return and then press tab to start a new line
Jan 30, 2014 | Nakajima AE-740 Typewriter
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
How do I get the automatic return off?
Try adjusting your right hand margin to be set as far across as possible and take the typewriter off proportional spacing and set it at 10,12 or a set spacing,this should stop it from doing this if not let me know
Nov 16, 2011 | Lexmark Wheelwriter 1500 Typewriter
If i hit the space bar it returns to a new line
You probably Have The R. margin set to close and you a re in auto return mode. Tab allthe way to the right, press R. mar. key. Press code and R to turn off the auto return.
DickyO
Dec 15, 2010 | Lexmark Wheelwriter 1500 Typewriter
Why when i hit the space bar it returns to the next line.
Hi:
You have Auto Carriage Return enabled. Hold down the code key and press the R key once to disable that function.
Andrew
Jul 23, 2009 | Lexmark Wheelwriter 3000 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Every time I hit the space bar, it types a character,
Check to see if the printwheel is in correctly.
Mar 02, 2009 | Office Equipment & Supplies
Brother GX-6750 Typewriter Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
