Question about Garden
I have a portible air compressor, with two gauges on it and it takes a long time to reach its pressure, also once reached it does not shut down
    Sergeant:
    Champion:
  • 250 Answers
Make sure the air intake filter is clean and make sure there is no leaks in the metal lines and hoses of the compressor by putting liquid soap around the fittings and looking for bubbles. If the compressor is used a lot you might have bad ring on the piston. Since it does not shut off when it reaches pressor the pressor switch might be adjusted right or if it does not adjust you have to replace the pressure switch.
Posted on Mar 15, 2011
What possible causes have an air compressor shut down before reaching max pressure?
The pressure switch needs adjusting or replaced. The power cord is attached to this switch. There is an adjustment screw under the cover.
Nov 20, 2015 | Air Tools & Compressors
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
Wont build up air presher on ec12
Low pressure ususally caused by faulty reed valves /gaskets in the head. Easy to check. When compressor reaches highest pressure, check for air blowing out of the intake or no or very little suction. If the compressor has reached highest pressure and you still feel very good suction, suspect air leaking out of system. Check all fittngs with soapy water or shut off the compressor and listen carefully for air leaks. Repair as needed. If faulty reed valves, you can make them using feeler gauge material or purchase from www.toolpartsdirect.com
Oct 21, 2011 | Hitachi EC12 Portable Electric 2hp Air...
I've got a Porter Cable pancake air compressor with, what I think is, a bad pressure switch. Plugged in, switch to auto, and nothing happens. Unit is bleed and gauge is at 0. I can get a new switch for...
You can test the other components of the compressor by temporarily by-passing the pressure switch. Connect line in to motor wires and plug in unit, unplug when pressure reaches 125 to 130 lbs. There is a safety relief just in case so do not worry. It the pressure does not reach target pressure there may be a leak or worn cylinder. If target pressure is reached in a short time replace pressure switch. Very easy repair. Good Luck.
Aug 07, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Air conditioner starts blowing cold air then blows warm
This is most likely the cycling of the AC unit. As the compressor pressurizes the 134a Freon you get the cold air, once it reaches a certain pressure it cuts out. If you are low on Freon it will cycle out more often. Check your freon level with a gauge to see if your within the proper tolerance. If the compressor runs for a period and doesn't reach the right pressure it will cut out to keep from damaging your compressor so it is important to keep the correct amount of freon in the system.
Jun 21, 2010 | 2002 Dodge Stratus
Will not shut off after pressure is reached, must shut off with switch
it sounds like the pressure switch is malfunctioning and should be replaced. I would recommend going to Dewaltservicenet.com and typing in your model number for a breakdown for this compressor and replacement parts.
Nov 19, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Dewalt 4 gal air compressor will not build pressure in take.
The bleed valve is an unloader of sorts that allows the compressor to start with-out a load. It closes when the pressure in the airline reaches about 20-25lbs with good volume. If air volume is not sufficient, the valve will not close. To solve the problem lets do a few tests. A long cord will reduce power and reduce air volume. Try powering the compressor with-out extension cord. If bleed valve closes when you do not use a cord, the compressor is not getting enough voltage, use shorter cord of the 12 gauge quality and more hose to reach work. If valve still does not close, check for air leaks on all fittings including around pressure switch and drain valve with soapy water. Repair as necessary and retest. If no leaks were found, temporarily plug bleed valve port with screw/bolt and run compressor till set pressure cut-off while counting minuites/seconds. The compressor should fill and shut off within three minutes or so. If it takes an unusually long time to fill, then the reed valves /valve plate is worn and leaking pressure back into cylinger. Leaking valves will usually result in very hot discharge airline/air. Reinstall the bleed valve after test. Parts and partslist are available at www.toolpartsdirect.com . Good luck on the repair and email if you have other questions.
May 06, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Oiless SearCompressor will not reach shutoff pressure of 120 PSI
There are only two reasons it will not reach shut off pressure. 1, there is a leak inside or outside of the compressor, leaking air faster than the compressor will deliver it. ( Do you hear hissing when you first shut off the compressor? If so this might be your problem) Second, the compressor is worn out, or needs repair. - Valves, rings, diaphhram etc. Take it to a repair shop.
Good Luck
Mar 17, 2009 | Craftsman Air Tools & Compressors
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
