Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
I need the passphrase for wireless network for my windows 7 starter
  • 1,591 Answers
The passphrase is whatever you made it when you were setting up the router's wireless security.
If you have forgotten your passphrase, you'll have to completely reset the router by holding in the reset button at the back for 10 seconds, and then reprogramming the wireless security.
You will then need to set all the other wireless devices you own to the new passphrase.
Posted on Mar 15, 2011
How to go to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots. These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel. To connect to Wi-Fi, you must have an enabled wireless adapter on your computer. Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities. However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna. Hold the "Fn" key and press this key to toggle wireless on or off. Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter. Attach the USB wireless adapter to an available USB port on your computer. Windows 7 will automatically install the necessary drivers for most adapters. If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers. Restart your computer if you do not see a wireless icon in your Windows 7 notification area. Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect. If this is your home network, the correct network will likely be the one with the strongest signal. Click "Connect" and enter the wireless security passphrase, if required. Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead. Open your browser and navigate to any website. If the hot spot requires browser authentication, your website request is redirected to an information page. Follow the instructions on this page to get Wi-Fi. This may entail clicking "Accept," entering a given password or entering a cell phone number. After authentication, attempt your website again to verify accessibility. Hope this helps
b>
Dec 22, 2012 | Computers & Internet
Tip
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
on Jan 22, 2010 | Computers & Internet
Can not get to wifi
Hope this helps
Oct 29, 2012 | Acer Iconia Tab A200
Cant get my windows 7 computer to connect to the dlink router, and every time i look for the 8 diget code on the router i cant find ic, can i have some help
Hi bradleyhagge,
Welcome to Fixya.
If you need you 8 Digit Code (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank. Go to the Wireless Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Don't Forget to say Thanks. Thanks for using Fixya.
Feb 05, 2011 | D-Link DIR-625 (790069292637) Wireless...
Once I have enabled WEP, how do I set up the
Access the setup page of the router by typing 192.168.2.1 in the address bar of your browser.
Leave the password blank.
On the setup page of the router, go to Wireless. Take note of your SSID. You may also change the name of your SSID so that you can easily identify your network.
Then go to Security under Wireless.
Select 64-bit WEP. Type a passphrase then click the generate button.
Take note of the passphrase and wep key.
Then click Apply Changes.
On your wireless computer, you should be able to detect your SSID in the available networks.
It will ask you for the network key, type the wep key. On some computers, simply typing the passphrase works.
I hope this helps!
May 15, 2010 | Belkin (F5D5231-4) Router
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
You can check the passphrase when you access the router page:
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
May 13, 2010 | Computers & Internet
Setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
Windows XP
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
I setup a netgear wireless router and once i try connecting thru a laptop using wireless connection it asks for the passphrase but once i put it in it says its invalid, why if thats the right passphrase??
what is the Operating system on the laptop ?
Sometimes on Windows 7 it will not accept the network key?
You will need rto change the security type to WPA
Change the wireless channel to 6.
try to change the SSID also.
then try to connect to the new network and see if that works.
You will need to open the set up page of the router.
click here for more info about routers and network
Jan 12, 2010 | NetGear WGR614 Router
Can't connect the artisan 800 to our wireless network
To add the printer to your wireless network, you need to know the name (SSID)
of your wireless network. If it has security enabled, you also need to know the
WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
■ Network name (SSID): _________________________________________
■ WEP key or passphrase: _________________________________________
Note:
If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
characters, it’s hexadecimal. The default WEP key is usually 1.
If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
The printer supports the following wireless security modes: WEP 64, WEP 128, and
WPA-PSK.
If you don’t know your wireless network name (SSID) or WEP key or passphrase,
contact the person who set up your wireless network before you begin.
Insert the printer software CD.
2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
When you see the User Account Control screen, click Continue.
Windows® XP: When you see the Software installation screen, continue with
step 3.
Mac OS® X: Double-click the icon.
3. Click Install.
1.Make sure that the printer is turned on.
2. When you see the FireWall Warning screen, click Next.
3.Make sure you connected the Ethernet cable
Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
I dont know my passphase
hello!
If you dont remember your passphrase or network key, you need to access the router page to check the router wireless settings. make sure that your computer is directly connected to the router to check your passphrase
Step 1: Access the router’s web-based setup page
Step 2: When the router’s web-based setup page appears, click Wireless
Step 3: Click Wireless Security and take note of the current Security Mode
Step 4: You will see your wireless network key or passphrase on this window
May 19, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
75 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
