Question about Air Tools & Compressors
My compressor does not stop running - Air Tools & Compressors
It most likely has a serious leak that needs to be located & fixed. Also check the pressure regulator it has an adjustment on it - turn it out (anticlock wise) for earlier shut dowm...
Posted on Mar 15, 2011
Hi, I have True T49F. When I plug in the system runs, but the evap fans was run. Then for a minute the Compressor frost up. So what do I need to check? Please help......
The compressor will appear to freeze up if the evaporator fan stops running while the compressor is running. I would look for a defective evaporator fan if I understand you correctly. Fans will sometimes stop when they should be running. Defective fan does not always stop running when they go bad
Appliance 911 Sea Breeze
Mar 14, 2017 | True Refrigerators
Whirlpool ed22mk xl fans run, starter is a solid state starter ge ic-13, 3arr42a2. Click, compressor vibrates, sounds like it us running, click, compressor stops.
call the technician for a proper diagnosis and quote
could still be the starter capacitor failure or a compressor seizure
Aug 28, 2016 | GE Refrigerators
Does air conditioning compressor have sensor for 2001 tahoe that can stop compressor from running
all vehicles have a low pressure sincere, to stop compressor if low on freon
Aug 22, 2015 | Cars & Trucks
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Compressor
A stuck contactor is basically the only reason why you wouldn't be able to cut the compressor off at the Tstat. Remove the low voltage signal wires from the contactor (powered by the Y terminal on the Tstat), if this doesn't stop the compressor, you need a new contactor.If this stops the compressor (open the contactor), then I'd replace the Tstat. The cooling issue can be caused by any number of faults, but don't be fooled into believing the compressor is running because the condenser fan runs. The compressor has a distinct dieseling sound while running. The compressor itself might be fine, but needs a run capacitor
Aug 29, 2013 | Heating & Cooling
Compressor wont stop running on my 1994 chrysler concorde
Could be a stuck relay or a problem with the clutch on the compressor.
Can you pull the relay or unplug the clutch to make it stop ?
Jan 27, 2013 | 1994 Chrysler Concorde
Does not cool either side fan runs and compressor seems to run
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Aug 19, 2011 | Maytag MZD2766GES Side by Side...
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
19 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
