Question about Samsung Computers & Internet
CD/DVD rom not listed in the device manager - Samsung Computers & Internet
Your OS is possibly too old for the new hardware
Posted on Mar 15, 2011
My samsung dvd writer can't read cd
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 23, 2011 | Samsung SH-S223C 22X DVD Writer SATA Black...
My Lenovo 3000 G410 Optiarc DVD/RW AD 7560A can t read just writed cd/dvd. But it dose not happend with the original/licence cd /dvd.
First you need to check your DVD rom drivers if it is detected in the Device manager window, Just click on Start , Control Panel, System then Device manager there you can check the list of all your devices.
  • In Device Manager look for DVD/CD-rom drives click the arrow or plus sign on the left to show he sub Menu.
  • Check to see if there are any Marks such as question marks, Exclamation Points or Red X's.
  • Hopefully there are none of any, if there is try uninstalling the driver then restart the machine it should automatically reinstall the DVD/CD-rom.
  • Now to get the not reading error, Click on Start, then on the Start Search Bar type on REGEDIT then press enter. mvincentc_35.jpg
  • This will open the Registry Editor Window.
  • In the Registry Window follow this key path = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Once the dvd/cd-rom appears a list on the Right pane window will show, on the list looke for upper and lower filters then delete both then close the registry window then restart you computer.
This should help restore you DVD/CCD-rom back to a reading state.
Have a nice day,
mvincentc
Mar 21, 2011 | Sony Optiarc AD-7170S Burner
My cd-rom is not visible i don't no what to do to enable it.
Well , i would suggest to check the device manager first if not listed under my computer. to check device manager. Click on start and click on run , type devmgmt.msc and click ok. if not listed then a power issue or connector issue if listed , then simply right click and uninstall it. reboot the pc....this is should help.
Thanks.
Nov 18, 2010 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Dvd/cd drive is not shown in my computer
1) Veify its listed in device manager? To check that Right click on My computer and got to manage.There you need to click on device manager.On right side, check whether you are able to see CD/DVD listed. see the pic
If its not listed you need to reconnect the power supply.
If its listed and still not working, check the IDE or Sata cable to connected to it.Refix it.
If you are seeing an yellow mark near CD/DVD drive you can download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html
2)Verify that the CD/DVD drive is detected by the BIOS when the computer starts
You can see how to access bios at http://www.fixya.com/support/r4268275-enter_bios_in_toshiba_laptop
3)Verify that the CD/DVD drive has a drive letter assigned in Disk Manager
a. Click Start, and then click Run. Or click Start Search.
b. Type “diskmgmt.msc” (without the quotes), and then press ENTER
c. Verify that the CD/DVD device is assigned a drive letter (for example, “D:”)
d. If the device does not have a drive letter, then right mouse click on the CD-ROM (highlighted in red above), and select Change Drive Letters and Paths
e. Click Add, click Assign the following drive letter, and then click a drive letter from the list
4)Uninstall & Reinstall the DVD/CD-ROM drive in Device Manager
b. Type “devmgmt.msc” (without the quotes), and then press ENTER
c. Double click to expand DVD/CD-ROM drives
d. Right-click on the name of your DVD/CD-ROM and click Uninstall
e. Select OK to the Confirm Device Removal (Windows XP) or Confirm Device Uninstall (Windows Vista) dialog
f. Right mouse click your computer name and select Scan for hardware changes
g. Close Device Manager
f: Click OK twice, and then close Disk Management
If all these not solved your issue you can have a look at http://www.fixya.com/support/r4274092-cd_dvd_drive_missing_or_not_recognized
Aug 19, 2010 | Computers & Internet
My dvd-rom doesn't work.what shoul i do? toshiba DVD-ROM sd-r2312
Please check the device manager for the DVD drive entry listed under CD/DVD drive. If it is not listed in the device manager then set the BIOs to default settings.
Jul 16, 2009 | HP Pavilion ze4300 Notebook
CD/DVD rom drive not working
Hi there.
It sounds like the drivers could be bad or the lens has gone.
This can be a common problem with vista loosing the CD/DVD drives.
Do this >>>>>> right click on "computer" and select "manage" from the sub menu, then select "device manager" from the left hand side, it will generate a list of devices, look down the list for CD/DVD and click on the + icon next to it, from the drop down list right click and uninstall, restart the PC and let vista re-install the drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Dell Inspiron E1405 Notebook
How can i download the matshita dvd ram uj 8505?
Hi there.
If its Vista you are using, right click on "computer", select "manage" a window will pop up, select "device manager" you will now see a list of devices, look down the list and locate the CD/DVD Rom, click on the + icon next to the CD/DVD, right click on it and select "uninstall". restart the machine and load windows up as usual, the drivers for the CD/DVD will install automatically and you should be able to use the CD/DVD Rom.
Good luck and thanks for using Fixya!!!!
Mar 02, 2009 | Compaq Computers & Internet
Dvd-rom not installed but not working
Right click on cd rom device with yellow mark and click on uninstall. after that cd rom device is deleted from device list.now right click on Home and click scan for hardware changes.now you got driver installation for your cd rom.if not restart yopur system you will get driver installation.
Jun 08, 2008 | Biostar P4M80-M4 Motherboard
DVD works but not regular CD ROM
try frimware update for it from site ok pioneer.com ok
Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Nov 09, 2007 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
