Question about HP Computers & Internet
Hi. How do I install my sim card for dv5-1034tx please? I can't seem to find the slot for my sim card. Thank you.
How can i use sim card slot on hp pavilion dv5 2045dx.
Posted on Feb 27, 2012
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 16 Answers
You can download the service manual from HP here: http://h10032.www1.hp.com/ctg/Manual/c01550108.pdf
Unfortunately from the manual it doesn't look like your laptop is equipped with a SIM slot - but you may wish to look through the manual in detail, to satisfy yourself.
Posted on Mar 15, 2011
I have Nokia E71 mobile phone. Since, about two months ago, I have problem with message "Insert SIM card". I need solution for this problem. I have last SW version. I tried hard reset and I take...
Inserting some folded paper behind sim to hold the sim tight to the slot does seem to have worked. Try it.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 18, 2011 | Nokia E71 Smartphone
I ADD NEW SIM CAR AT MY SAMSUNG BUT ITS SAY EMERGENCY CALLS ONLY
Did you try to use anyother SIM card.Please try any other SIM card and check whether it is working.If it is working the problem is with the SIM card.If it is not working it its with the SIM card slot in the mobile.You need to service the mobile.
Thank you
Jan 21, 2011 | Samsung SGH-A877 Impression Cell Phone
Sim card is in the phone, but the phone displays insert sim card
hi
there must be fault in the sim pin in the card slot.. contact your service provider and check the Sim pin of your mobile.. this may needs to save the pin card slot of the mobile.. try to change the Sim card slot.. vote for this answer
thank you
Dec 26, 2010 | Motorola Mobility V365 Cellular Phone
I have bought a Samsung Galaxy S but after I inserted my sim card and operated for almost 2 months, I removed the sim card from the unit and reset the phone to its original state. Now this phone could not...
hi
check the sim card slot of your mobile. may be it get damaged . if so change the sim card slot.
this will fix the problem . and also format the phone .. this will fix the problem..
thank you
Dec 20, 2010 | Samsung Galaxy S GTI9000 Smartphone
Where is the memory card slot in z550i?
hi
have a through look of your phone if the slot is not available. just remove the battery from the phone and check near the Sim card slot. because some phone has a slot near the Sim card slot.. just check the phone..you can also refer the manual of the phone.
thank you
Dec 20, 2010 | Sony Ericsson Z550i Cellular Phone
How to place Sim how to open
The SIM card slot is located at the right panel of your device. Below the SIM card slot, you will find the storage card slot. The battery compartment is located at the back side of your device.
You will be able to download the user manual for your HTC Phone from the link below.
Download Manual
Download the manual and it will show you how to use the smartphone.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HTC Touch P3450 Smartphone
What is the sim shaped slot under the battery of lg xnote..how it can be useful
Hi.
Based on the information you have provided, it seems that the Sim shaped slot which you are referring to is the Slot which can be used to insert Wireless WAN Air card.
By using this Air card, you may connect to the Internet.
For further information about the Air card, you may contact the Computer manufacturer.
They should explain you about this in detail.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | LG X-Note LM50 Notebook
IMEI No
when u press *#06# your phone shows imei and imeisv no. , so actually only one sim has a valid imi no.
so u have to to a valid imei installation shop n have to get a valid imei installed
Jan 12, 2010 | Handmark Software MobileLists (950142) for...
Memory card installation
hi,
does your motorola Razr have a Memory Card Slot?
is you Razr model is V3re or V3 only.. (this models doesn't have MMC slot)
is your razr is V3i or v3x or v3xx then the MMC slot is located at the back closed to SIM card.
Jun 09, 2008 | Cell Phones
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Computers & Internet Logo
268 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
