Question about Polaroid FLM-3232 Television
V-chip block comes across screen and blocks out channel i never set any passwords but to enable this it is asking for a passcode
  • 3 more comments
  • jennysweet5 Aug 04, 2008
    the factory preset password still did not allow me to remove the v-chip block
  • jennysweet5 Aug 07, 2008
    v-chip block pops up on tv n blocks out channel. i tryed using 0000 code didnt work
  • Anonymous Sep 23, 2008
    I have the same issue
  • Anonymous Oct 16, 2008
    I have same problem!
  • Anonymous Feb 22, 2009
    Same problem, entered the 0000 default, and it acts like its the wrong password and I never changed it.
8202 worked on my model 3700. Thank you rgmedrolf
Posted on Jul 10, 2010
  • siniko1 Jan 25, 2012
    thank you it worked for me too ;)
Try password 8202 0r 8205 worked for me
Posted on Jan 20, 2010
From the service manual:
The factory preset password is '0000'. This password must be used first before setting your own personal password.
Posted on Aug 03, 2008
My IPad has been hacked into I need to. Know how to change my password.
With the push of a button and pull of a slider, you can quickly access all of your iPad's contents, including any sensitive personal data that you've stored within it.
Such easy and unrestricted accessibility to your device could be dangerous in the hands of a stranger, which is why you enable a password to block its use by anyone but you.
If you believe that your password's confidentiality has been compromised, don't fret. You can change it using your iPad's Passcode Lock feature.
Tap "Settings" on the home screen.
Tap "General" on the left sidebar.
Tap "Passcode Lock" on the main pane to the right.
Type your current four-digit passcode in the "Enter Passcode" screen that appears.
Tap "Change Passcode." Type your current four-digit passcode again in the first "Change Passcode" screen that appears.
Enter a new four-digit passcode in the second "Change Passcode" screen.
Retype your new four-digit passcode in the third "Change Passcode" screen.
This will simultaneously verify and activate your new passcode.
http://support.apple.com/kb/HT4113
iOS: Using passcodes
http://support.apple.com/kb/ht1212
iOS: Forgotten passcode or device disabled after entering wrong passcode
Jan 13, 2014 | Computers & Internet
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Cannot watch TV, kids set v chip and I do not know it
Turn the volume down to 0 then change to a blocked channel. (where it asks for v-chip password) Next, on the TV, not from the remote, hold the volume down button, and hold the '0' key on the remote for between 2-10 seconds... the screen should unlock and you should have no V-Chip restrictions.
Jan 23, 2009 | Orion1934 19" TV
Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
MENU
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
CANCEL ENTER
. Press _ to set the passcode and go to
theV-chip ratings menu.
MENU
4. To exit without entering a passcode, press _ to
HOME
go to the previous menu or _ to return to
television viewing.
IMPORTANT
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
65
Nov 24, 2008 | Mitsubishi VS-55707 TV
Polaroid FLM-3232 Television Logo
696 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
