Question about Miele G2470SCSFSS Dishwasher
F11 appears on the display ?? what can that be from.??
  • 1,998 Answers
Water outlet is restricted,water remains in the cabinet at the end of the cycle page 46 of your manual tells how to fix this error by reading under the care and cleaning section of your machine http://www.miele.co.uk/products/manuals/dishwashers/G1220_1230_2220.pdf note this is an older model then yours but the error codes have not changed nor has the cleaning part if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations Thanks Rick
Posted on Mar 15, 2011
  • Sortedtx Mar 27, 2011
    Very helpful many thanks! If you stay calm and follow the manual instructions this wiorks like a charm !
Automatic appear f11
try another keyboard
Mar 24, 2014 | Samsung N150 Netbook
F 11 DISPLAYS
What is the model number of your unit?
Nov 18, 2012 | Indesit Washing Machines
My kenmore he2 plus keeps giving me an f11 code...I cleaned out the pump and it appears to be working...it fills with eater but does not move at all then pumps the water out ..next it gives me an f11 code
What the F11 means per the Manfactures service manual says "Serial Communaction Error" to put that in simple terms it says the main control board isn't talking to the motor control board. What would need to checked when the F11 code is displayed is for good tight wire connection on all the wiring harnesses between the main and motor control boards, if all the wiring plugs fit tight onto both control board while i hardly advise this and belive in the you can do it byself spirit it , but call for service so the operation of both control boards can be checked to see which on has failed.
Oct 07, 2011 | Kenmore HE2 Plus Front Load Washer
Fault code F11 keeps appearing. The washer seems to be working but within seconds of starting to wash, F11 appears.
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
F11 appears
F11 appears to be a Serial Communication error (a digital signal problem between the motor, motor control unit, and the central control unit). Look for loose connectors on each of these items. The wiring harness may be at fault, or any of the above devices (sounds expensive). Good luck!
Nov 17, 2009 | Kenmore Elite 45986 Front Load Washer
F11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
I need to reset my Dell Latitude D820 to when it was new and came out of the box. Dell told me to restart and press ctrl F11 when the Dell logo appeared, that did not work. Tried the same thing with just...
You have to press F11 and keep on pressing it but not hold it down. Some menu appears, wouldn't know because i got an HP but with Dells should have a menu for system restore. So just press and keep on tapping it till some bios menu appears that give you more options.
Sep 19, 2008 | Computers & Internet
Whirlpool duet wahsher
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Miele G2470SCSFSS Dishwasher Logo
1,486 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
