I have an eldectalog stove heater, worked wonderful all winter until now. the "Lights" come on but no matter the settings I change on the back it continues to opperate like the no heat setting. I'm wondering if there is something inside i need to replace like a light bulb. there is nothing within a foot of either side or within 5 feet in front and its not overheating because the heat isn't ever coming on? What should I do.
    Brigadier General:
  • 4,736 Answers
The system may need resetting. Turn the Master ON/OFF switch to OFF. Unplug the unit and wait 12 to 15 minute. Plug the unit back in, turn the Master ON/OFF switch to ON and operate as you normally would. If it reset it should work normally. If it doesn't the heat overload switch has failed and needs to be replaced.
Posted on Mar 15, 2011
What are the pros and cons of operating the Quadrafire Mt Vernon AE pellet stove in manual mode?
They probably cannot suggest running it on 'manual' due to liability reasons....leaving home for an extended time and forgetting its on manual...comes to mind.
What may be suggested is to make sure ANY and ALL safety controls still function to shut off fuel (pellet) flow in the manual mode as an extended overtemp condition is the first thing that comes to mind when you think of damage to a heating system or to the structure within which it is installed.
I think its a judgement call on your part once you determine you pretty well KNOW the full and complete operation of the device. The key to that statement is KNOWING WITHOUT A DOUBT the FULL operation of the system.
I also would NEVER recommend to a customer to operate it in the manual position.
Mar 25, 2015 | Heating & Cooling
First time owner. Have tankless water heater. How do I de-winterize the RV?
De winterizing is easy. They use a pink antifreeze which is food grade. Make surer the water heater is not by-passed. This is sometimes done using furnished bypass valves so that less antifreeze is needed. You can flip the water heater pressure release after connecting to city water. Water will come out if it is full. Do NOT turn on the water heater until you are certain the tank is full of water so as not to burn out the element. (This is true every time you set up) Run all faucets until you no longer see pink and you are de winterized.
Mar 10, 2015 | Jayco 2013 Greyhawk 31DS
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I was wondering if it was normal to hear "crackling" noises coming from the unit after plugging it in for the first time since last winter?
Depends, it could just be the heater warming up and expanding or it could be an electrical crackling from something shorting out which is not good and it should probably be replaced.
Nov 23, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
1999 toyota corolla
If you are running your ac, this may just be condensation from the air conditioner.  Do you see puddles in the winter, or when you do not run your air conditioner?  I live in a humid climate, and every summer, no matter what car I have had, I have experienced this same thing.  I have been told that it was just condensation, and as long as it was water (colorless/odorless) it should be fine.  Of course you should take it to a licensed mechanic to verify that there isn't something more serious happening.  As a temporary check, though, you might try driving around for 20 miles or so without the air conditioner on and then park for a few minutes and check for a puddle/leak.
Aug 30, 2008 | Coleman Mach 15 Air Conditioner
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Jun 15, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
