Question about Music
Hi my mixer on the right hand side doesn't work, it keeps telling me that its an error and wont eject the disc that it has in it.
  • Music Master
  • 5,603 Answers
Some of the failures to eject a disk problems are due to failure or slipping of a little drive belt that moves the carriage out. Also sometimes the alignment is bad and the disk hits the front escutcheon.
Posted on Mar 15, 2011
Serious Doubts of NuMark Authorized Repair/Dealers
This is normal practice. Manufacturers keep the service information in house and only supply their agents.
Mar 15, 2014 | Numark Industries Numark 5000FX 5 Channel...
Allen and Heath PA 28 is making pulsating sound, lights blink for left and right channels and the sound can be heard throught speakers. It won't go away and it is impossible to use the mixing board. ...
You haven't given us much information... You obviously have some sort of feedback and saturation in process. First thing is to unplug ANY signals into the unit including any inserts and see if problem goes away. If it does, start adding them back in. If it doesn't go away with only the main outputs then VERIFY that you are using BALANCED interconnects to your amps/speakers AND that the mixer AND all of these amps/speakers are powered from the SAME receptacle or power conditioner module. If the BARE mixer with only headphones has the problem, then you have a power supply in the mixer that is squeging.
Nov 03, 2011 | Allen & Heath PA28 Effects Mixer
Peavey pv14 right side stop working all of a sudden how do i fix it?
you could have blown the output on that side,, here are some other things you may need to know about that mixer http://bose.infopop.cc/eve/forums/a/tpc/f/8566055944/m/3281007943 I have seen the manual for this unit in the past and it really doesn't give many details of what all can be used for this mixer,, However that seems to be par for most unpowered mixers, I do know that if your using a mic with it,, its very choosy on which ones work , and those that have issues
Sep 11, 2011 | Peavey Electronics Peavey PV14 Mixer
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Could you send me the best set up starting with 1 for setting up our new XR 8600 Powered mixer in our church. We have 3 bose loudspeakers on each speaker output. Should those Bose be set for 100 watts...
Sorry, but you have a problem. The amp is rated to 4 ohms per side. Your speakers would have to be 16 ohm type to allow 3 per side in parallel. The Bose ratings are usually consumer type ratings and they would have to be set to 200 watts each (twice the rating that the amp can produce per side) to be safe connected to that amp. Your speakers are likely 8 ohm so you could parallel ONLY two per side OR if they are 4 ohm, then you would have to series them. You could series two or three per side safely for the amp. You don't tell us what model Bose speakers you have. Anyway, one has to first meet the specs of the amp and the speakers to avoid damage. It is likely the amp is too BIG for the speakers. For the setup of the mixer portion of this problem I want you to view videos on YouTube. Search for "mixer setup". Don't worry that they are different mixers than yours... there is enough commonality and the functions are nearly the same for MOST analog mixers. Recommendation: forget about two of the speakers... keep them as spares and run low volume to avoid blowing the speakers. I can't imagine any competent audio equipment supplier configuring your system this way.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
DXM09 MIXER ADAPTOR
Often the cord has broken wires. First try to repair the power supply.
Also check the connector in the mixer as they can get damaged by side pulls of the cord.
Sep 28, 2009 | Numark DM1200 DJ Mixer
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
42 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
