Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Refridgerator Not Cooling
We had trouble a few months back with the fridge overfreezing. We unplugged the unit and plugged it back in and that seemed to solve its problem for a while. Now it seems that the freezer is fine...a little frost is appearing but staying cold. But the refrigerator sensor seems to not be working properly. We have it set to 7 and its barely cold. We have thrown out contents due to this issue at this point. We unplugged the unit again...a few times in the last couple of days and you can hear the unit making the differing noise that seems like it may be generating some cold (possibly) and then it shuts off after about 10 seconds after we plugged it back in...and again the fridge doesn't seem to be cooler at all. It seems to be a sensor not reading correctly since the freezer works but that is just a guess. Any ideas? refrigerator not cooling properly, freezer working fine
  • thekeeslers Aug 04, 2008
    I have the same issue, any assisstnce would eb greatly appreciated.
    Problem Solver:
  • 6 Answers
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Posted on Aug 07, 2008
Fan was working . Removed back cover found ice block covering vent to refrgerator. Turned off freezer and thawed out with hair dryer .
Posted on Sep 16, 2008
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Ffa47x fridge not cooling freezer overfreezing
there is a little air passage that allows the cold air form the freezer to cool the refrigerator is blocked or jammed closed check that first then you can get back to me
Dec 30, 2011 | Hotpoint Refrigerators
Is it possible to remove refridgerator, and clean under it? Bad smell under fridge. Help!!!!!
yes, in the back of the unit unplug the fridge and open the back panel with a few screwsand you should be able to reach underneath
Sep 07, 2011 | Refrigerators
Fridge not cooling
unplug unit and let sit overnight to defrost,
Oct 29, 2009 | Refrigerators
Our refridgerator is not cooling well.
These units only have coils on the freezer side and just blow cold air to the other side through small ducts. These ducts have a tendency to ice up and block the airflow. Do a manual defrost for about two (2) hours and then plug it back in. Hope this helps. Good luck.
Jun 05, 2009 | Admiral Refrigerators
Refridgerator stops cooling
Check the compressor relay near the compressor on the back bottom of the fridge. Check voltage it should read about 115, up above that there is a computer sensor, check that also has a fuse on it. One of the two is bad, they are cheap part and you can find them on LG.com
Feb 09, 2009 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
GE Refridgerator
I suggest that you check your defrost heater in the freezer. If this is the problem, then if you empty out the freezer section you will see a solid sheet of ice on the back panel. If the ice is there, then you may need to replace your defrost heater, we had this same problem just a few days ago. Once the heater was replaced, the fridge started cooling about an hour or so.
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The coil was frozen on my unit as well. Guinco tech Ron announced that this was a bad system board. Seems to be resolving as of this writing.
Jan 02, 2008 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
280 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
