Question about Sanyo DP42746 42 in. Plasma Television
I have a sanyo DP42746 that won't turn on at all. I've checked the two lines coming out of the power filter board with a multimeter and both show 60VAC when I check each w/ respect to ground. I think that makes sense and is sending the appropriate voltage into the main power board. After following the schematics i noticed 5V_stb, 3.3V vias on what I believe is the main power board, and when using the multimeter pin in the vias receive 0v on each. I believe this is the same test point as is referred in the manual but I'm not certain. Any tips?
  • Sanyo Master
  • 2,098 Answers
If you didn't get the 5v,3.3v in the output of the chopper transformer it means that it didn't gone to a complete cycle. You have a problem in the main voltage regulator circuitry.
Check the reading and let me know to assist you further.
Jdvillanueva
Posted on Mar 15, 2011
Sanyo model dp42746 powers on but black screen and no audio
Clicking noise is usually produced by a shorted load or overloaded SMPS (power supply), black screen as you had mentioned may contribute to a short circuited load.Check voltages (secondary) might be pulsing from high to low that sync the clicking sound.Checking load resistance through filter capacitor will help a lot then try isolating circuit branches to localize the shorted or leaky parts.Try isolating(one at a time) the power supply's loads may help a lot.
May 26, 2012 | Sanyo DP42746 42 in. Plasma Television
Sanyo turn it on green light comes on and stays on but tv will not model dp42746
open back panel and look for error code
to test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Oct 03, 2011 | Sanyo DP42746 42 in. Plasma Television
I have a sanyo dp42746 i have to turn on and off 50 times it will come on and stay on play like new but if i shut it off i have to turn on and off all over agian what could be wrong
Power supply board that the problems and the causes.That the board,where the power a/c cord plug into it.You have all the tools and understand basic electronic and soldering?Yes.Check all over of the power supply board for parts that call capacitors are dying,these capacitors are alway bulges up or puffing up on it tops.These capacitors must be replaced to solved this delaying power to turn on to the tv.Or try website like Ebay.com to buy awhole refurbish power supply board for the replacement.
Jan 04, 2011 | Sanyo DP42746 42 in. Plasma Television
Sanyo 42 inch plasma not turning on, not power showing
Power supply board it dead,must replaced the power board.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 06, 2010 | Sanyo DP42746 42 in. Plasma Television
Our sanyo dp42746 went black made a pop sound and would not turn back on no power light or nothing
Most likely a power supply board went bad. the pop sound is bad capacitor on the board. Most bad capacitors will look like this: 18976c2.jpg
The other picture below shows a normal capacitor in the middle, but two bad capacitors on the sides of it. One with the dome top and one leaking. 5d53c3a.jpg
You can try repairing the board by replacing the capacitors or replace the whole power supply board. Most replacement boards can be found at a good price at Shopjimmy.com or Ebay.
Dec 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma No Video
Apr 12, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
60 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
