Question about Whirlpool Dryers
Whirlpool Electric Duet Dryer made a very high pitched noise when on then it would stop about ten to fifteen minutes later. After three days of this the sound stopped and the dryer would stop after 30 sec. and smell like something was burning. what happened!
softplanway
  • 53 Answers
SOURCE: My Duet Whirlpool Dryer (had this #8519498) has burning smell
I am not the Dryer fixin' trade...but I have this dryer. To me, it sounds like it overheating or the heater unit has become lose from its hold rack. I would MOST definitely have a pro look at it and do NOT leave the dryer unattended...It may be a possible fire hazzard
Take Care
Wayne
Posted on Jan 03, 2008
SOURCE: Burning smell
We had the same problem. After we used it a few times, the smell went away.
Posted on Sep 07, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
How do I diagnose/fix my Whirlpool Duet Electric Dryer which won't turn on.
access electric motor and disconnect from dryer, jump wire the motor with a wire with plug to see if motor is burnt out.
Jan 18, 2016 | Whirlpool Washing Machines
LEC8858EQ0 starts and then shuts off
You have a problem with the motor overheating. Replace the motor and you should be good to go. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | Whirlpool Dryers
Whirlpool Duet dryer is making a high pitched screeching noise. Model gew9250pw1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Whirlpool Dryers
My whirlpool duet electric dryer will turn on run for a minute than turn off and smells hot
Check the dryer vent,some times they will get stopped up with lint causing the dryer to shut off on high temperature.
Mar 03, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Drum will not turn on dryer makes a high pitch shrill when you push the button
u are going to need to replace the dryer drum drive belt and inspect the rollers the drum ride in, here is how to replace the belt.
please follow the safe link to the how to site on your dryer.
http://www.instructables.com/id/How-To-Replace-a-Dryer-Belt-on-Whirlpool-Models/
Jul 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My Whirlpool Gold dryer makes a high-pitched squealing noise for about 5 minutes when first turned on, then stops and dryer continues cycle. The noise doesn't sound like metal on metal but more like a...
CHECK BELT,TENCHEN ARM (KEEPS BELT SNUG),ALSO ROLLER WHEELS...
SOMETHING IS GOING BAD BUT ONCE IT WARMS UP IT STOPS MAKING NOISE.
YOU NEED TO FIND THE PROBLEM BEFORE IT BREAK DOWN???
LATER FREDDY
Feb 11, 2010 | Whirlpool Dryers
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
Dryers Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
