I have a bonaire evap cooler, it is about 15 years old I think, it has a 750 watt variable speed motor. Recently the motor brackets broke, I replaced these but the motor seemed to have a "torque spasm" causing the motor to twist exessivly which led to the brackets breaking. I replaced the motor but it still has this "spasm" not as severe but I am worried that the mounts will break again. What else can be wrong or am I just paranoid?
  • 1 more comment
  • epveenhof Mar 15, 2011
    Thank you for your response, I understand the torque at start up, but what I am talking about is once the speed has stabilised it is a jerky twist at a regular interval and is worse at low speed than at high speed, probably because the frequency is higher at the high speed. Could there be something wrong with the electronic speed control, perhaps on the cicuit board? Since the brackets have lasted at least 15 years I must presume that they should be okay. Regards Evert
  • epveenhof Mar 16, 2011
    I have a bonaire evap cooler, it is about 15 years old I think, it has a 750 watt variable speed motor. Recently the motor brackets broke, I replaced these but the motor seemed to have a "torque spasm" causing the motor to twist exessivly which led to the brackets breaking. I replaced the motor but it still has this "spasm" not as severe but I am worried that the mounts will break again. This jerky movement is at a regular interval and the frequency increases with speed but is let severe at high speed, could it be something faulty in the speed control?
    Hi thanks for the response but I don't have a belt drive, this is a direct drive, the original motor still runs and has no burnt coils or smells this is why I think there may be something wrong with the speed control. Regards Evert
  • 359 Answers
I am assuming you are talking about the fan motor. The motor should be ok, a torque "spasm" can be expected when it starts unless it has a drive to bring the motor up slowly. You didn't say that there is one, so I assume again that there isn't. Though it is variable speed; even if you start it on low the fan will have its largest load, you can check the alignment of the belt if there is one to the fan. If its a direct drive you can check the alignment of the shaft to the blade. I personally would pick up some brackets, or uni-strut and reinforce the mounting plate to put less strain on the motors standard brackets. I believe that would put my mind at ease. Hope this helps. Let me know if you need further assistance.Thanks.
Posted on Mar 16, 2011
  • Alan Conner
    Alan Conner Mar 16, 2011
    For there to be a torque spasm while running it sounds like you may be right regarding the speed control. the speed control may be shorted, or worn out causing a spike in amps to the motor. I presume this is a single phase system, but another thing to check is that the motor may be kicking over to the opposite direction. I don't have any pictures of it, so I can't be positive. But a lot of electric motors have directional controls as well. If you could send a few pics that would be great! thanks.
    President:
  • 1,515 Answers
Hi, these motors do twist some, but not enough to break the bearing hold down clamps. Some torque is normal. The old ones were just weak and probably rusted. Check your belt for the proper tightness. If it is to tight, it will cause this. Take your index finger and with power off, push down in about the middle of belt. There should be about 3/4 of an inch play in it. You are probably a little paranoid from the first motor, but this is normal for these high torque motors.
Shastalaker7
A/C, & Heating Contractor
  • Robert Horton
    Robert Horton Apr 10, 2011
    I am not sure if you have solved this problem, but knowing this is a direct drive motor and it has a motor control, this would be your problem. This control board will cause this variable speed motor to go crazy if you loose the control board, and cause excessive torque on the mounting brackets. We use these on the new a/c units now, and this happens a lot when the control has a problem, the motor will be fine, but the control board its self will fell causing all heck to break loose. I hope you are up and running. No beefed up brackets are needed, as it didn't come with it anyway, it is a matter of a new motor control board.
    Shastalaker7
    Genius:
  • 1,165 Answers
750 watt motor is very powerful. Going from the "off" position ot the "hi speed" position on the fan control may be what is causing the sudden torque. Start at the lowest fan speed, and give the fan time to normalize at each speed before going to the next higher setting. If the excess torque still happens, more sturdy brackets may be necessary. If the fan "on and off" is controlled by a thermostat, setting the fan speed to the maximum speed could cause "torque twist" each time it starts up. Try running it at a lower setting and see if the torque is more manageable.
Posted on Mar 15, 2011
  • Jackie Miles
    Jackie Miles Mar 16, 2011
    Sorry, Evert. I don't have any more ideas. Hopefully, another expert will be able to help you. Good luck.
New fan motor gets hot and stops after an hour have new computer
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
Dec 22, 2016 | Heating & Cooling
Bonair Evap Wont turn on after power failure
Hi bud do youself a favour before anything else take the main motor out and send it in to a reputable electrical repair co such as dynamic electrical in Benoni or look up a similar co near you and make sure that your system has not been hit bye lightning or a power surge from the supplier first I do own a Co that specialises in evap coolers and from previous knowledge a lot of the new systems have 12V inverters and if there has been a storm and you havnt diconnected your unit the PCs and motors are more than likely fried
Feb 17, 2014 | Mastercool 67471 Evaporative Cooler Air...
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Servicing
Yes I would think so,a good r&r cleaning,once a year.
Nov 16, 2009 | Heating & Cooling
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
Fan is slow
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Jan 30, 2009 | Dometic Rooftop RV Air Conditioner
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
How many Watts on the B & D M205S
200 Watts! I have owned the M205S for 15 years! YUP! and used it to death! Doesn't owe me a penny! But I am so upset, because although the 200 Watt motor is still running great, one of the beaters just broke off. I didn't know if replacement beaters are still available for such an old model?
Dec 31, 2007 | Black & Decker 200 Watts MX85...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
