Question about Garden
I want a head and line for jcb 96/db/lwa strimmer
2 Suggested Answers
  • 122 Answers
SOURCE: What fuel mix for a
40:1. Which works out at 25mls of oil to every litre of petrol.
Found the above answer on another site, 40:1 in the U.S. is 2.6 oz. of 2 cycle oil to 1 gallon of gas.
Posted on Sep 04, 2011
I have a jcb strimmer wont start does it have any points
no points on a single cylinder possibly a bad coil
Sep 04, 2016 | Garden
How do I add line to strimmer head
There are hundreds of makes and models and styles of strimmer head. PLEASE state the MAKE and MODEL when asking questions. It makes them easier to answer instead of trying to guess what type of machine you have. Thanks
May 10, 2016 | Garden
Jcb plt25 fuel tank parts
At a store that sells garden machines. Take the line you need with you as there are various size fuel lines.
Aug 17, 2014 | Garden
Jcb jz70 lacks power
Sounds to me like you have a hydraulic lever or pedal open and its dead heading against a closed port. Possibly to an attachment line. I'm not sure about the JCB on this, but if you can put other attachments on the unit, there has got to be an actuating lever or pedal to open the attachment lines for actuation.
Jun 20, 2014 | Vehicle Parts & Accessories
Hoe does the automatic line feed work on a line trimer
Richard the auto line feed works by bumping the head when the strimmer is running. If it's wound right the line comes out when you tap the head on the ground when on full running.
Jan 12, 2014 | Garden
I have a jcb 25c 2stroke petrol strimmer and the engine pulley has broke and come away how do I reattach it?
This is a tricky one. You haven't said if the screw holes have worn. If they haven't you need to re tighten the spring manualy. Then put carefully back over and re screw.
Jun 19, 2013 | Garden
Jcb strimmer plt 25f
If there is a spark at the plug, and the plug gets wet with fuel after pulling, the remove the muffler and check the condition of the piston through the open exhaust port, if there is any signs of scuffing then the motor has seized and will require stripping down, if the piston looks good, check the fly wheel key has not part sheared, they are usually alloy and part of the flywheel itself.
Jun 02, 2013 | Garden
What fuel mix for a JCB M25 Strimmer?
Sep 04, 2011 | Garden
Garden Logo
207 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
