Question about Brother LS-2125 Mechanical Sewing Machine
How do I set my machine so it does a basting stitch? I tried with the last stitch under 6, but it didn't seem to work. I'm making a ruffle and it didn't work when I tried to pull the threads. Is there a way to make a larger distance between stitches?
  • 192 Answers
SOURCE: Husky 165 - won't do a basting stitch
Set the machine to its longest stitch length, put it in the warmest room in your house and in the sun if possible. If the stitch gets longer when the machine is warm it needs to be cleaned and lubed so that the stitch length mechanism moves freely.
If the lube in the machine is getting old or is nonexistent, the reverse button may be depressed and appear to return to its original position, when released, but the mechanism inside the machine only returns part of the way causing the length to be shorter than normal. Heat often masks this problem allowing the mechanism to move.
Posted on Nov 14, 2007
SOURCE: Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
Posted on Aug 24, 2008
  • 16 Answers
SOURCE: ruffler/gathering foot
There is a ruffling foot for brother machines. Google Brothers sewing machine feet and I am sure you will find a automatic ruffling foot.
Posted on Sep 15, 2008
  • 66 Answers
SOURCE: Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Posted on Jan 29, 2009
bargainbox
  • 1388 Answers
SOURCE: Huge loops on back of fabric!
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Aug 02, 2009
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
May 11, 2016 | Sewing Machines
Feed dog low.Notpulling.Checked setting for sewing/darning, it was set right. Tried levers, moved the basting stitch nob to L and R and...the needle bar jumped up like 5 inches, into the head.
Difficult to diagnose without the make/model. However, if it has a basting stitch, that could be one problem. Some machines with a basting stitch have a problem with it sticking and preventing the machine from working properly. Also sounds like perhaps the feed dogs are dropped for darning and are not pulling the fabric through the machine--or the stitch length is set too close to zero so the stitches are sewing in one place or on top of each other. Make sure the machine does not have a darning foot installed--the darning foot is shorter than standard feet so there is space between it and the needleplate. Also, some machines have the ability to increase/decrease the presser foot pressure that will affect the way fabric is moved through the machine.
Recommendation is take it for service.
Jan 07, 2016 | Sewing Machines
Kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
Mar 13, 2012 | Sewing Machines
I am wanting to set my machine (quilters dream 6603) for the best basting stitch I can. I am having trouble figuring out how to set the machine. Thanks.
I haven't been able to find a 6003 manual or a good image of the stitch range for this machine on line. However, a basting stitch might look like " . _____ . _____. " on your stitch selector. As your machine is targeted for quilters I'd have expected it to have a basting stitch in its range.
If there is nothing like that, then just dial up the longest possible straight stitch, ie take length up to 4 or 5, whatever the maximum number is. Then loosen off the top and bottom tensions and stitch away.
If you are using this to baste a quilt top, botton and batting together, I've discovered a product called "spray basting" which is fantastic and "glues" the layers together while you sew them. You need a big clear floorspace though and put paper down under the project. But it works great.
Trust this is of help to you.
Apr 12, 2011 | Elna Quilter's Dream 6003Q
What settings do I use on my singer 6038c to make simple basting stitch and a simple ruffle
Use the longest stitch length and loosen top tension,. Practice on a piece of scrap material until you are satisfied with the results. Good luck
Oct 24, 2010 | Singer 6038 Mechanical Sewing Machine
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Ruffler/gathering foot
Sep 05, 2008 | Brother CS-8150 Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
152 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
