Question about Lexicon Omega Desktop Recording Studio Sound Card
My cubase LE4 software says the ASIO driver Omega ASIO cant be started? i follow the directions and try to record but the track remains blank
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 15, 2011
Hello I am trying to install CUBASE LE4 for usewith my Zoom H4n recorder but having diffultity getting the ZOOM H4 ASIO driver as mentioned in the setup guide. thanks pat
Hello Pat, you will probably have to download driver from the internet. I had a similar problem with another synthesizer software program. Even though the HD series Zooms come with cubase cds, they are not always compatible with the pcs. You should be ok after that.
Mar 23, 2011 | Computers & Internet
Can i use behringer 200vmx usb to mix only with him and my pc trough usb cable,and only usb cable!!!! i have 5.1sound card, and asio driver?
Depending on the DAW software, you can record just his track at that time. Mixing can be done later with multi-track software, such as Cubase or ProTools.
There should be an extra device in the volume controls under your OS's control panel. That extra device will be your USB mic. Select this device for recording. Monitor the input recording levels BEFORE actually recording to check for clipping. When you are adjusted correctly, you should have plenty of volume, and no clipping. From there, you can modify that waveform like any other track.
Hope that helps!
Feb 10, 2011 | Audio Players & Recorders
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
WDM Driver failed to install is the first of four
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Nov 13, 2009 | Lexicon Omega Desktop Recording Studio
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
H4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Aug 28, 2008 | Zoom H4 Handy Recorder
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
Trouble getting started
find the lexicon usb driver in device manager. uninstall it and reboot and let plug and play install a generic usb driver from windows.
I think this might help.
goodluck
44hink
Jan 19, 2008 | Lexicon Omega Desktop Recording Studio...
Open Questions:
See all Lexicon Omega Desktop Recording Studio Sound Card Questions
Lexicon Omega Desktop Recording Studio Sound Card Logo
319 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
