Question about BenQ Computers & Internet
Mhat would cause scrolling lines on a benq monitor they are there even when it is not connected to a pc the benq screen comes up when power is turned on but it is pink with horizontal lines scrolling upward .also seems to have 1 line in the center of the screen . then goes to no cable connected screen still with all lines.
Had a sinilar problem with an acer 19" moniotr, turned out to be the DC power supply board. If you know someone with an electronics background get them to check it out for you. I was able to repair mine in an hour, keeping in mind, I had all of the proper tools and parts on hand to do the job properly. If you dont know what you are doing I wouldnt recommend attempting a repair, due to high voltage supplies inside.
Posted on Mar 22, 2011
    Problem Solver:
  • 9 Answers
It sounds like you have some dead pixels in you monitor. i suggest if its still under warranty return it immediately because if not your going to have to buy another monitor if you can live the with lines there. hope this helps.
crm8
Posted on Mar 15, 2011
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Apr 08, 2010 | BenQ E2200HD Monitor
Screen not displaying appropriate display at start up
Vetical line is the sign of failing LCD controller (t-con) board, which is part of the LCD panel assembly, it will get worst with more lines. You can try looking at the ribbon cable that is attached to the LCD panel and the Logic board to see it is not seated properly. You can look at what the connection looks like here:
http://s807.photobucket.com/home/budm/allalbums
You may also look for bad caps in the logic board and power supply board also.
Apr 07, 2010 | BenQ FP202W Monitor
Trouble with my BenQ monitor
As a general rule, this is a panel failing.
The panel is working for a few minutes until it heats up then begins to breakdown. Blowing air onto it wont help since the area in question is under another panel inside the monitor.
The video control board (inside the monitor that converts signals between your PC and the physical panel) could be failing.
Another source of the problem, though rare, is the capacitors that filter power for the panel's power supply (on the main powerboard) begin to break down and that is enough to cause the issue.
Because this is a BenQ, it may come back to life if you replace any capacitor that looks even remotely suspect & resolder all the main components on the powerboard.
Be warned, there are dangerous voltages stored by the main filter capacitor that can kill even if the monitor has been unplugged for several hours.
Peter
Mar 26, 2010 | BenQ FP71G 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
My Benq screen shuts down 10 seconds after switchung on
it may be overheat or check the cables it will properly connect or not(may be loose connection or damaged).
click this link for more info
Feb 22, 2009 | BenQ FP731 17" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
Unexplained Blank screen.
Looks like your Power Supply has gone Kaput .. Usually it is the Electrolytic Capacitors on the Power Supply Board, try a new one, or replace ALL the Electros with same or better ones.
Jun 21, 2007 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
269 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
