Question about Yamaha PSR-S500 Digital Keyboard
Display is intermittend - Yamaha PSR-S500 Digital Keyboard
  • Yamaha Master
  • 5,603 Answers
Yamaha apparently had some problems with these displays according to the forums... If you are out of warranty then the repair will likely be at your expense. If in warranty, go on record immediately. Replacing the display is not really DIY unless you are electronically competent... I don't know what the cost for the display is, however you can call Yamaha America in CA and ask for "parts" and tell them what you need and ask the price. I can tell you there are a LOT of screws to remove to access the display and cables that must be cared for.
Posted on Mar 16, 2011
  • gammonsdl May 18, 2011
    I ordered the display from Yamaha America. Cost $169.00 plus tax. Gonna try it myself as I have no choice. Local Yamaha repair estimated $250.00 to replace the diplay. I only paid $300 for the unit used, still it's too nice to trash. $169.00 for the display was painful enough. The repair manual makes the repair look relatively simple.
Yamaha tyros 2 liquide display screen problems
needs a new display...call yamaha parts dept
Aug 15, 2012 | Music
Korg ax3000 g display not working
It is likely something internal. The LCD is backlit so there is a chance it may be something on the order of a bad connection at the power supply input. Possibly a broken wire- as long as unit was not dropped, using a multi meter to check power is a pretty straight forward way to proceed.
If it got wet, there is possibly a burned out pico fuse, or corrosion on a connector or contact area for the rubber conductors for the display.
If unit was dropped- You may want to contact Korg to see if the display board is available. It likely is not. Which means it is a time and or money investment.
Feb 12, 2012 | Korg Music
Psr-s500; no display at all but everything else is working properly.
Read your manual about a contrast control for the display. At one end of the range of control the display is almost invisible. Sometimes there is a little shaft/knob on the back, other times it is a menu item and yes, it is hard to see the display to adjust the display... just go through the procedure blindly to see if it comes back. Also illuminate the display if dark with a flashlight and see if there are display characters there but just lacking a backlight. A backlight failure could be the problem.
Aug 27, 2011 | Yamaha PSR-S500 Digital Keyboard
PA800 - Screen is blank
You want to ADJUST the display "contrast" which is described BRIEFLY on page 15 of your user manual under
COLOR TOUCHVIEW™ GRAPHICAL DISPLAY
PRESS and hold the MENU button and turn the DIAL to set the contrast...
Hopefully your display is just set at max brightness and you can adjust it.
Jan 31, 2011 | Korg Pa800 Synthesizer
Hi theres nothing showing up on the blue screen
If sound is going through this, then the display is the only problem. Some of these use a gas-discharge display and when cold or haven't been used for a while, they don't start right away.
If this might be the problem you can try helping the display ionize by shining a bright, perferably Halogen light into the window of the display. Let unit warm up and set awhileto see if display will come on.
Jan 06, 2011 | Peavey 16FX 16 Channel Mixer
My Fostex MR-8HD recorder's LCD display won't show me anything when I turn on the recorder. Everything else power's on and works properly. I can even hear it it working. I can't see the LCD display...
Check if the display has a contrast control. When these get turned down, the display is blank. Sometimes they are a littel shaft coming out of the case, other times it is a setting in a menu... how they expect you to see the display to set it in these cases is beyond me...
Oct 22, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
The display of my roland XP-80 is Zero, & theres no pragrams or voices, patches display... & the worst is there`s no sound because there is none in the display Pls. kindly give me an advise thank...
The procedure at this link shows you a battery replacement procedure that should work for you:http://ztup.com/Roland-D110-Battery-Replacement-Guide.htm You will need to design new user patches if you didn't back them up.
Jul 06, 2010 | Electric Music
Tuner
In the navigator display in the upper right corner of the face, after holding the tap switch or the tap footswitch for over two seconds the display will indicate your tuning. Strike an open string and the left end of the display will show you the note. Then there will be left and right arrows on the screen until you adjust your tuning for that note. When in tune for that note, two asterisks will be displayed in the center of that display.
Read your manual on the page with the "Smart FX" at the start.
May 14, 2010 | Line 6 Spider Iii 30
Blank display no functions power ok
Not sure what you mean by "power OK",
If you have checked that the logic circuits are getting a clean 5 volts DC THEN the power is OK. This requires an oscilloscope AND a voltmeter.
USUALLY when a display shows characters like that it means the processor hasn't initialized the display. Most common problem is too low power supply that doesn't permit the processor to come out of reset.
Bad filter caps can cause the 5 volts to dip below 4.6 volts which would be minimum to operate. A voltmeter might still register near 5 volts but a scope will show the voltage dips.
Jan 12, 2010 | Alesis Sr 16 Stereo Drum Machine
Yamaha PSR-S500 Digital Keyboard Logo
270 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
