Question about American Audio Mx-1400 12-inch 4 Channel Mixer
I want to plug my mxp - 1400 mixer into my computer and i have no idea on how to go about it
  • 3,400 Answers
You need to get cable from Radio Shack or Guitar Center that has "mini jack" (comp end) to stereo pair of 1/4" TRS or XLR ends (mixer side) Guitar center has for $9.00
Posted on Mar 15, 2011
Qfx1222 usb/hp envy computer - no sound frm mp3 music files
When you connect your laptop to the behringer mixer via USB it effectively uses the mixer as the audio interface.
You will need to hear the audio through the mixer either through headphones or external speakers.
There is no way that I am aware of that you can route all audio back through your laptop's speakers.
Mar 16, 2017 | Music
I dont know how to set up a mixer Gemini 3610 to my laptop and my powered speaker i want to know what cables i need
There are several possible solutions for this. The cheapest and easiest is to do the following:
Solution 1:
1. Get an RCA stereo plug to 3.5 mm plug. This will go from your mixer to your computer. This will not be the highest quality, but will work.
2. Get an XLR cable of the length you need. I would guess a standard one with a male connection on one end and a female on the other. Connect this to your powered speaker. Also, this is a guess as you didn't include the type of powered speaker, so I can't tell you for sure which cable to use.
Solution 2:
1. An alternate idea for better sound quality would be to run a D/A converter similar to this one: http://www.sweetwater.com/store/detail/USBMix/It would give you a much higher sound quality for everything. You would run from your Gemini to this. From this device, you would run a USB cable to your computer, and a 1/4" cable to your powered speaker.
Jul 19, 2012 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Feb 06, 2012 | Soundcraft Efx12 12-channel Mixer With...
On my Behringer UB1202 mixing board none of the inputs work. I plug headphones into the headphone jack to monitor. Neither dynamic nor condenser microphones work (with phantom power enabled when...
Does your computer Recognize the mixer. and to answer your question honestly Behringer is Junk they make cheap knock offs of really expensive products. but see if your computer recognizes it and if not i sugguest taking it back
May 13, 2011 | Behringer XENYX 1202 Premium 12-Input...
Cant hook computer to mixer for you tube music
You would need a stereo splitter taking a 1/8 inch stereo plug for the computer into two 1/4 inch jacks to plug into two channels of the mixer OR a 1/8 to 1/4 TRS cable that you go into the Stereo (L) of one of the stereo channels... OR a 1/8 inch splitter to RCA plugs going into the TAPE input jacks of the mixer. You can't really go via the USB cable easily from YouTube,
Mar 30, 2011 | Behringer XENYX 2442FX Mixer
Hi im sorry if this sounds a little dumb!!! last weekend while i was on a gig i tried to hook up my lap top to my mackie mixer (cfx12) but i wasnt able to get winamp to play through it, which channels...
With a stereo splitter cable that takes the stereo 1/8 plug of the computer into two RCA plugs you could go into the "Tape Input" of the mixer... OR take a 1/8 stereo splitter cable from the PC splitting to a pair of 1/4 inch plugs go into one of the 4 stereo input pairs on the mixer... like 7 and 8 or 9 and 10 for example.
Dec 22, 2010 | Mackie 1202vlz3 12 Channel Mixer
Getting a high pitched hum that is coming from the usb connection on the back of the mixer running into my imac. i disconnect the cable and the hum goes away. ideas?
This sounds like a ground loop. Make sure ALL (including the computer) interconnected devices are powered from the same receptacle. Make sure there are no lamp dimmers around as these can cause hum...
Dec 19, 2010 | Mackie Vlz3 802 8 Channel Analog Micline...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Mixer doesnt send sound to my computer
If you are using recording software you will have to look for Preferences and make sure that the software is detecting your soundcard. You also have to make sure that your PlayControl settings match the input on your soundcard to the ones your mixer are plugged into. You also have to match the RecordingControl which is under Options and then Properties. That is all under Sounds and Audio Devices in your Control Panel under the Volume tab then Advanced. If you have latency problems which makes the sound delayed from the input on your mixer to what you hear from your computer try downloading Asio4all although your mixer should have come with a disk with the proper drivers. If it didn't Behringer has a great support section at their site that has downloads for everything.
Aug 07, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I need to know where you plug the guitar cord into the mixer
you plug it in to any channel you want just lick a mic.
there you go DFD
Mar 18, 2009 | Yamaha Mg102c Stereo Mixer
American Audio Mx-1400 12-inch 4 Channel Mixer Logo
41 people viewed this question
Top American Audio Music Experts
Vito Vacirca Jr.
Are you an American Audio Music Expert? Answer questions, earn points and help others
