Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water leak Periodically, a pool of water shows up in front of the unit, it's not leaking constantly, and I can't find the source. Any ideas?
  • sjwcp Sep 03, 2008
    Same issue, pool of water comes from water dripping from a screw near the front right foot of the refrigerator (freezer side). Where is the condensation drain that might be plugged? And where we you poor the bleach in?
Replace the freezer gasket!
Posted on Aug 25, 2008
There is a problem with the condesation drain being plugged in the bottom of the unit. The water is supposed to drain onto a "condensation pan" under the unit where it typically evaporates without causing problems.
I believe that the solution was to pour bleech in the drain...
Posted on Aug 18, 2008
Water is leaking from refrigerator forming pools of water on floor.
You need to pay attention where the water is coming from. If the water comes from doors, look for magnet seal broken or spills from the inside the fridge. If the water comes from the bottom (or back) of the unit, it may be an installation issue.
Once you locate the source, it will be easy to fix.
May 08, 2010 | Refrigerators
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator leaks
Could be nothing is broken. There is a drip pan under the refrigerator. It accepts water from the defroster. The water is supposed to evaporate before it gets full. It ought to be cleaned periodically, as it gets nasty with mold. Could be the pan is displaced or cracked.
Nov 10, 2008 | Samsung Refrigerators
Water Leaks from front door
My tenants informed me that water was showing up on the floor in front of the refrigerator. I checked the back where the evaporator tray is and it was dry. When i looked inside the refrigerator I notices water pooled inside, under the plastic bottom drawer. Anybody have any idea what i should do? thanks.
May 29, 2008 | Refrigerators
Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Jan 08, 2007 | Frigidaire FRS26R4C Side by Side...
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
