Question about Plumbing
The drain in shower is pitted in places, appears to be made of a chrome plated metal. Is there a way of resurfacing it without replacing.
    Genius:
  • 1,739 Answers
Here is an informative piece on chrome plating:
http://www.finishing.com/faqs/chrome.html
The cost to have a piece replated may be prohibitive. You would want to get an estimate and perhaps compare to the cost of purchasing as replacement. Some possible sources are below which could provide a good comparison for replacement cost:
http://www.plumbingsupply.com/draincovers.html
or
http://www.shopping.com/plumbing-supplies/drain-cover+drain-application-shower/products
Posted on Mar 15, 2011
Metal handle adapter for single handle shower monticello cannot remove it
Did you remove the Philips screw that holds it in place? If you have and still can't get the adapter off try heating gently with a torch.
Feb 16, 2014 | Moen T3129 Chrome Monticello Single Handle...
Shower hose keeps disconnecting from metal connector
It seems you may need a new hose. You can contact Hansgrohe Tech at 1-800-334-0455 and we can handle the replacement for you.
Apr 10, 2013 | Hansgrohe 28274000 Techniflex 80in....
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Jun 24, 2009 | Grohe Movario 59" Metal Shower Hose -...
Cannot remove shower holding plate
After removing the 2 allen wrench bolts in the holding plate, place the flathead screwdriver on the plate and using side of group as leverage lift. Check diagram below92b399a.jpg
May 27, 2009 | Gaggia Carezza Espresso Machine
Screechy shower curtain
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
Upside down
Yes there should be an easy answer..unless the valve assembly was sweated in upside down....there should be a plastic plate in the center of the handle...that allows access to the screw that holds the handle on (now if I remember right you have to have a MOEN tool (specialty tool ) to remove the valve stem and these seat in only one way...but I believe the handle can be rotated 180 degrees as the valve has a rectangular duplicate sided appearance unless this is something I have not seen ...and I used to work at an Apt community that had nothing but moen fixtures. Try flipping the handle assembly...and usually the chrome plates slip up over a sleeve some have 2 screws one on each side...if so take these out and invert the plate......I hoper this helps...good luck...please rate me....The Fang
Mar 26, 2009 | Home
Watch case
This is more of a manufacturing than a support problem. However, if you would like to have the watch resurfaced or restored a qualified jeweler should be able to acid wash and plate it for you. It depends on the value of the watch (monetary or sentimental) and how much you're willing to spend. I wouldn't expect plating to run much more than $150 but you'll want to make sure you're clear on the end result (shiny, brushed finish, tinted, etc.).
Nov 10, 2007 | Watches
Plumbing Logo
111 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
