Mouse no longer working can't get it to move I switched with another mouse I had which is working and it did not work either when I connected that one too
    Sniper:
  • 60 Answers
Make sure you're shutting down your pc completely before connecting the mouse. Once connected power your computer on and see if it works.
If it's a USB mouse try a different USB port.
Posted on Aug 01, 2008
Laser no longer working
I have a feeling that the wire has a break in it it should be an easy fix Check for continuity with a multimeter.
Nov 28, 2013 | AZiO Levetron Laser Gaming Mouse GM-2000 /...
Hi my mouse has worked for years. I just changed the battery in the mouse and now it will no longer work. The jump drive turns red when I push the mouse up to it then nothing happens. I went to Control...
From your description, it sounds like the wireless connection between the mouse and the USB receiver (jump drive) isn't resetting. Here are the steps to reset the connection after changing batteries:
With the computer on, mouse on, and receiver installed in the USB port...
1. Turn the mouse over and aim the front at the receiver, like this:
thomascha103_8.jpg 2. Press the "connect" button on the bottom of the mouse. It's small and round, next to the power switch.
3. Then press the "connect" button on the receiver
(the connect buttons always have to be pressed in this order)
4. When you press the button on the receiveer, the light will turn on. Keep the mouse pointed directly at the receiver until the linkage is complete and the light turns off.
That whole process has to be completed in under 60 seconds. If it takes longer, you'll have to start over.
At least, that's how it works for me. Here's a link to the user manual with other helpful troubleshooting tips:
http://cache-www.belkin.com/support/dl/f8e825-usb.pdf
Best of luck!
Jan 20, 2011 | Belkin Mini Wireless Optical Mouse...
Having replaced batteries on a Dell mouse and keyboard, switched on keyboard and mouse not working. Dell support window says both connected? Cannot move mouse to acknowledge message saying that new device...
If the keyboard is working, try the "tab" key or a combination of the "tab" and "shift,ctl or alt" key.
You should be able to move the cursor to highlight to Ok message, then hit return.
Dec 29, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Pluged it in lites came on computer said ready to use but wont work
In that case, that means that your mouse is physically connected to the computer and was able to detect it. But if the mouse pointer doesn't move, that means that the sensor hardware in the mouse is no longer working. If buttons are the ones that does not respond, it means that the switch hardware in the mouse is already faulty. Problems such as these are hardware problems and the only solution is to replace the mouse. If it is still under warrany, have it replaced by the shop or the manufacturer.
Nov 06, 2009 | Logitech Cordless Mouse
Optical mouse no longer works
I doubt the problem is the battery, and you do NOT have to press the Connect button each time you use the mouse - it will connect all by itself if it can. The Connect button is only used to re-establish connection if for some reason it cannot connect automatically.
I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light, so that it gets pressed when the receiver is inside the receptacle. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Nov 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a kensington wireless mouse. the wireless keyboard works, but the mouse does not. The red laser light is on, but it won't move
Have you tried to resync the mouse with the receiver. Usually,you need to press the button on the reciever first, then quickly hit the button on bottom of the mouse.
Oct 05, 2009 | Kensington Computers & Internet
The mouse seems to be frozen, when you start the laptop up it is no longer possible to move the mouse. I have tried left click, drag and right click but nothing seems to work, including contal alt del.
Your touchpad may have stopped working either from it is damaged or somehow the driver/software was diabled or removed. You could try re-booting in safemode and see if the mouse can move to verify the touchpad is working. Also try using a usb mouse to see if you can move the indicator with that so you can try to re-install the drivers/software.
Sep 13, 2009 | Compaq Presario CQ60-220US PC Laptop
Philips freeline wireless keyboard and Mouse
Have you tried re-installing the software for the keyboard & mouse. It sounds like a driver is missing and the best way to solve it in most cases is to re-install the software from the disk that came with the Keyboard & Mouse. Hope that helps. Bud
Jan 05, 2009 | GE Wireless Optical Mouse
Cant get Pointer to move
First try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Then if that doesn't work try
Hope this helps you. Bud
Feb 19, 2008 | Dynex Wireless Optical Mouse DX-WOM100
Computers & Internet Logo
David Payne
David Payne
