Please solve my problem that shows fatal error ie. qp.RES fatal error.
    Problem Solver:
  • 9 Answers
Hope this works write me back if it doesn't. First go to Start -> Run -> msconfig and hit Open. Hit the Selective Startup radio button on the main screen and then hit the Startup tab. See if any references to the program you removed are in here, and un-check them. This should work!
crm8
Posted on Mar 15, 2011
How to sove the fatal error fatal error: Failed to load menumanager:'local:menusystem\mainmenu.qsc' please help me to solve this problem.
Yes that is out of memory the chips are running out of memory because of age you can reform it but it will not improve, sorry.
Jul 29, 2014 | Codemasters IGI 2 Covert Strike
How to solve the error of directx message on project igi?
i don'T have a good english either. but you can look for your current dx version by typing dxdiag in run command and clicking run. update if necessary.
Mar 18, 2012 | Project IGI IM GOING IN
Qp.res file is missing.fatal error.
It seems that you have deleted something from your computer. For a simple fix go to Start -> Run -> msconfig and hit Open. Click the selective startup radio button then click on the startup tab. See if there are any references of the stuff that you recently deleted and un check them.
If that does not help use a good Windows registry cleaning (or fixing) software and use to scan and remove any of the remnants of the software you removed. This can also help.
Jul 13, 2011 | Computers & Internet
Showing 121: fatal error
It is not exactly "fatal", it is related to LSI power supply or disturbance in it communication with high-voltage LSI chip, try this solution first:
1. switch off the printer and remove cord from power supply, remove network connection as well.
2. switch printer on (without power!) for 20sec, switch off
3. connect power supply, and switch printer on
4. connect network cable
If this operation did not clear the error, unfortunately you need to service the printer.
Hope this will help to solve your problem, please leavenote how did it go.
Aug 17, 2010 | OKI C5500n Laser Printer
The display is showing Service Call 132:Fatal
I solved this problem easily (Once I found it!)..open lid, locate where the top section bright metal lugs contact with copper leaf contacts at the front of the base unit and clean them with some fine emery paper or gently with small flat screwdriver... mine had a bit of toner dust and a tiny carbon deposit which was preventing the circuit being made. This showed the fatal error 132 and you may notice on start up that the normal rotation noises within the machine were silent too. Worked for me. Problem arose after Xmas break when machine had been stood for a few weeks. Good Luck! Bryan at Pinewood Studio Manchester.
Nov 17, 2009 | OKI C9600n Led Printer
Iomega Screen Play HD showing fatal error 05 -
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Sep 25, 2009 | Iomega ScreenPlay
GTA 4 FATAL ERROR: RESC10
If you are trying to run it on a PS3 console, Try to upgrade you'r PS3 console
Aug 03, 2009 | Rockstar Games Grand Theft Auto™ IV for...
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error
Fatal Error K (for BLACK) - Black toner or drum problem, Drum life exceeded? Display would of said black drum near life before failing.
May 15, 2007 | OKI C5100n Laser Printer
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
