Question about Dynex 5-in-1 USB 2.0 Mini Memory Card Reader
When iplug in my dynex reader the program doesnt pop up to show my programs in my card.
  • 902 Answers
Plug in the reader without the card then put in the cards. i had a model that did this too and i had to junk it. i hope that isnt your issue but thats the only two solutions glad i could help. sorry for the bad news i hope i dont get a thumbs down for this lol
Posted on Mar 15, 2011
Why doesnt my sd card reader work? I put in my gateway laptop and it doesnt work nothing pops up??
You might just have a bad SD card. Also, if you bought a card that is 4gb or more then you need a SDHC card reader. The HC stands for High Capacity. Look at the card to see if it shows HC under the SD. If it does then you need to find out if your card reader can read SDHC. If it can't then you need to go buy a new card reader that can do SDHC.
Jan 28, 2011 | Computers & Internet
Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
May 29, 2010 | Dynex External USB 2.0 Multiformat Memory...
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
I cannot find the file, My Dynex memory reader is plugged in, both green lights are on, but nothing is popping up. It worked last time, but instead this time when i plugged it in, it made the noise that...
Try rebooting and see if it shows up properly. If it doesn't, there could be a conflict with driver letters.
Right-click My Computer and choose Manage
Left-click Disk Management
See if your device is listed there. If it is try assigning it a new Drive Letter Right-click and choose Change Driver Letter and Paths.
Click Change.
Choose a new drive letter, problem something lower than E.
Click OK.
Unplug and reattach your device and see if it will work properly.
Aug 29, 2009 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
My green light won't go off on my dynex webcam
It sounds like your webcam software is hanging on to a program somewhere, and the chat program thinks its already in use.
This is unusual, insomuch that the webcam continues to transmit - almost as if its being forced by another program.
I always disconnect and re-connect the webcam to reboot it before going into chat, but its never had the light on.
Have a good scan of your programs to ensure you have no redundant webcam software creating conflicts.
I would suggest you uninstall the software - disconnect the webcam and install new software
http://www.dynexproducts.com/pc-692-10-dynex-13mp-web-cam.aspx
Aug 26, 2009 | Dynex DX-WC100 Webcam
Dynex dx-cr121
I suspect that you have already rebooted the computer with the card reader in place. If not, give that a try, this will cause Windows to load the drivers at startup, rather than as a plug and play device.
Also, you may wish to check the card reader manufacturers website for an updated XP driver.
Jul 07, 2009 | Dynex External USB 2.0 Multiformat Memory...
Sd card reader doesnt seem to work
I had the same problem as you describe on my Medion P6611 laptop (and on a previous Medion desktop that was, sadly, stolen from my apartment in early December. But I digress...) I called Medion tech support (which I have never found to be anything less than excellent), and the representative said:
The problem *may* be due to a buildup of static electricity, either on the card itself or in the card reader (I forget which it is). To fix it, do the following:
  • Tturn off your computer, remove the battery and unplug the AC power adapter from the laptop if it's also attached.
  • Press and hold the power button for 60 seconds or so. (This discharges the electricity from some internal component[s]--capacitors, perhaps?)
  • Replace the battery, reconnect the AC adapter (if you use it) and turn on the computer.
With any luck, that should fix your problem.
P.S. One slightly related tip: When you remove a card from the card reader, just remove it. There's no need to click on "Safely remove hardware" and select the card reader's drive letter. If you do, it won't recognize cards again until you reboot or turn the machine off and back on. Different problem, but same behavior.
Dec 22, 2008 | Medion md40298 Notebook
Dynex memory card reader problem
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 02, 2008 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
I bought a dynex cardreader for my apple computer
You have an apple iBook?
Don't install any software for the memory card reader.
Just plug it into the USB port on the iBook and open a Finder window (from the desktop hit Apple/N) or click on the desktop, then go to the menu at the top, and in the FILE menu select New Finder Window.
The card reader will show up as long as it has a functioning memory card in it. There is no need to install any software.
With Apple computers this is generally true with any peripheral, including printers and other devices. The Apple operating system has much better support for peripheral devices than what you might be used to with PCs, and generally additional software or drivers is not needed, and allowing the computer to do it automatically is much more trouble free, and obviously easier.
For audio and PA System expertise and help with feedback with your PA system, see my website at www.rexark.com
May 24, 2008 | Dynex External USB 2.0 Multiformat Memory...
Dynex 5-in-1 USB 2.0 Mini Memory Card Reader Logo
59 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
