I cant find power cord for my wd 1tb portable harrd drive what voltage ac plug can i use? D33015 N3565 E101559 THOSE ARE SOME NUMBERS ON HARD DRIVE
    Scholar:
  • 114 Answers
Dear Dodgeydude
you can buy the adapter directly from http://firstmybookexternalharddrivezone.blogspot.com/2011/02/pwr-ac-adapter-charger-switching-power.html
where as the specifications are Input : AC 120-240V Output : DC 12V 2A (1.5A Compatible)
please dont forget to rate
Gagan
Posted on Mar 15, 2011
My external harrd is not working.a baser sound is hearing.what i do?
Hi Arun, try to rmove the driver and reinstall it again, you do it in this way : Go to Control Panel and press on devices here you find the driver for you external drive and right click on it and choose remove driver. Remember for finding the driver you need to have your device inserted to the computer. Hope it helps otherwise return here
Oct 01, 2014 | Western Digital 1TB WD ELEMENTS USB...
Wd e101559
Install the hard drive in to a new usb enclosure assuming the hard drive itself is not the cause of the problem.
Jun 22, 2013 | Western Digital WD My Passport Essential...
My wd hardrive wont power on
look at power pack and look for the polarity diagram. get a multimeter and test the power that the pack is providing and make sure it is outputting what the pack says it is supposed to. if the pack is not at correct voltage, then this is most likely your problem. find another pack (MAKE SURE VOLTAGE AND POLARITY ARE SAME!!!! if voltage is correct but polarity is backwards, cut cord and swap wires before post to change it, or find another pack.) If the power pack checks out, then you need to open the WD case up and inside you will find a standard desktop 3.5" hard drive. most likely sata. remove from case and install it in a desktop computer and see if it will power and mount. if it will then the circuitry in the WD case is bad. If hard drive will not mount or show up then the hard drive is bad. If The WD case is the problem check circuitry for bad caps, transistors and voltage regulators. replace as needed. or just keep the hard drive in your pc as a permanent upgrade.
Sep 18, 2012 | Western Digital My Book Essential 1TB...
WD Software will not load up, and Windows keeps giving me an I/O error. With the I/O error, I am not able to see or access any files that I have on my WD MyPassport 1TB, SN WXD0AA9W6561
Have you tried another USB port.Try not using a USB hub and plug it into a different port on your PC. Also try temporarily disabling your virus and anti-spyware program. My virus program Antivir always blocks my WD software. There may have been an update that now blocks it. Check all your cables and plugs on the WD drive and if still not working try starting your pc in safe mode and see if the WD drive is recognized. Hope this was some help, Thanks for using FixYa
May 11, 2011 | Western Digital My Passport Essential SE...
The WD My Passport 1TB won't work on Windows after I formatted it for Mac.
You need to reformat it on windows. Plug it up then find it on your computer and format.
May 09, 2011 | Western Digital 1TB My Passport Essential...
WD external HDD my passport 500 Gb . It's not correctly installed into my PC - PC can't find driver. System Windows XP
Maybe it's a power issue. Try a shorter usb cord or try a different usb port. If you are using an usb hub, try to connect the hard disk straight to the pc.
Feb 28, 2011 | Western Digital My Passport Essential SE...
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Western Digital 1TB Portable Hard Drive has NO POWER
Well if you are still inside the warranty period, you can claim for a replacement. Also check the drive with other PCs. Reply if you need more assistance
Jun 24, 2009 | Western Digital Elements powered by WD 320...
1,747 people viewed this question
jasbo
jasbo
