When the engine gets hot under load it looses power and shuts down and will not restart until it cools for about an hour.
  • 902 Answers
Please clarify as you posted this as a website problem. what engine is getting hot?
Posted on Mar 15, 2011
Air runs until car runs a distance and engine is shut down. when restart air is not cool?
Well of course not. When you shut the car down, all water circulation stops so engine heat goes way up. This means the radiator gets hot too, and therefore so does the AC condensor. It takes time for all these things to cool back down when you start it back up.
Jul 14, 2015 | Cars & Trucks
Wipers work about 5 seconds then stop until engine is shut off about an hour. Then repeat.
Sounds like the windshield wiper motor is getting too hot. The wait an hour is waiting for that to cool down.
The wiper motor is located usually under the hood, on the firewall on the passenger side.
You should be able to feel the wiper motor getting too hot when the wipers are turned on.
Hope this helps.
Mar 30, 2015 | 1996 Ford Explorer
I have 84 ramcharger started fine used for about 1/2 hour plowwing driveway shut off would not restart until cooled off 2nd time it has done this?
Sounds as if the ignition control module is getting hot and not allowing it to restart. Had the same issue with a Dodge b-250 van, except for the plowing part. It would run for about an hour and start sputtering and shut off. After it cooled down, van would start and run great for the same length of time and do it again.
Feb 22, 2015 | Dodge Ramcharger Cars & Trucks
Power supply
Your fan needs to work to cool the processor. Sounds like it is getting too hot and shutting down/restarting. Once it is cool, boot into the OS and check your event logs which should give an indication as to why but it does sound like a heat issue
Mar 21, 2014 | Acer Aspire X3400 PC Desktop
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
My Cub Cadet 2130 has a Kohler Command 12.5 Hp engine. I have had a recent problem where if I shut the engine off after running for a half hour or so it won't restart. Today it died on it's own...
You most likely need to replace the ignition module. You should find it under the shoud next to the flywheel, just follow the spark plug wire.
Sep 18, 2011 | Garden
After a long drive, won't start when hot. Usually cranks after cooling down .Before this started,it ran hot but the temp guage was not reading hot.The motor shut down and would not start until the engine...
definatly crankshaft position sensor, had same problem hour ago and changed it and started right up.. crankshaft positions sensors are known to cause this problem, stays open circuit when hot.
Jul 07, 2009 | 1997 Buick LeSabre
98 honda shutts off and will not start until cooled off
you say the engine shuts down when it gets hot if it runs rough before doing so it could be the coolant temperature sensor allowing the engine to  overfuel  if the engine cuts out in a couple of seconds but sounds smooth it could be the fuel pump , if it cuts out instantly its electrical.
Mar 21, 2009 | 1998 Honda Civic
Overheating
If you did indeed overheat the engine to the point that is stuck, you would probably know it by the antifreeze being poured all over the ground. The bike would be really hot just sitting on it. It would smell like antifreeze and just smell hot.. I know, smell hot? but an engine that has been ran to hot has a pretty distinctive hot smell... It doesnt sound like an overheating situation if none of the above happened. A bike that is overheating will begin to loose power before it stops. LIke lacuna said, everything inside of the engine will start to expand from the heat and the piston will stick in the cylinder. Most of the time when this happens, the bike will cool off and restart. But, usually with problems. Warped or cracked head, cracked block, broken piston rings. These engines are aluminum and dont like to be overheated and warp really easy. If the engine is really hot, it will not turn over until it cools down enough. Im not saying it couldnt have overheated and then restarted without any problems, its happened before, but just not likely. But, if this is the case, take lacunas advice and change all of the fluids. Your oil will be nasty. Maybe get ahold of the previous owner and see if it has had any probems. It kinda sounds electrical to me. as long as the above overheating signs didnt happen. If you dont think it was overheating and it happens again, try to push start the bike to see if the engine turns over. even putting the bike in second or third gear just see if you can move the bike back and forth. If nothing else, you'll at least know its not locked up.
Nov 20, 2008 | 2005 Honda FMX 650
When engine get hot it looses fire and shut down will restart once cool
Check electric fan on radiator if bad will cause this problem
Jun 29, 2008 | 1995 Ford Taurus
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
