Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Error code 50 - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
    President:
  • 2,246 Answers
Error Code E50. This printer error code flashes when the fuser unit of your Brother multifunction printer gets damaged. When this happens, it is a signal that you must replace your printer's fuser unit
Posted on Mar 15, 2011
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
How to fix error code 50 on EFX 5.21i?
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
May 22, 2014 | Precor Exercise & Fitness
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
Error code 50
On Hewlett Packard printers a "50" error code is a fuser error.
Aug 18, 2010 | Office Equipment & Supplies
What is error 50 on the precor efx546
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Error 50 code, have replaced fuser and checked connections
I am not sure this will stay fixed but after i cleaned the pcb's and checked the connections and let the unit sit overnight the printer works just fine. If this does not stay fixed I will contact you again.
Thank you,
Apr 14, 2009 | Office Equipment & Supplies
Cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
50" sony wega blinks red at intervals of 3
The light is flashing an error code to you telling you what the problem is with the set. Either refer to your handbook or go to the Sony website to find out what the error code means. Hope this helps.
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
389 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
