Question about Thomson TE1152 Top Load Washer
Water leaks at last stage of wash for Thomson TX898. How to fix it?
3 Suggested Answers
vest6
  • 196 Answers
SOURCE: Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Posted on Jan 15, 2008
SOURCE: My Thomson TX898 washing machine,
I have the same problem 2, DO2 on Thomson TX898
Posted on May 28, 2011
My thomson machine TX898 got error code d17
google the brand-model#-error code
May 21, 2011 | Washing Machines
Thomson TX238 drain hose leaking.
Disconnect from power supply , remove screws , remove panel.
Nov 09, 2009 | Washing Machines
When my washing machine is filling with water at
Replace seals this will usually resolve this issue.
Aug 28, 2009 | Washing Machines
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Spinning problem
I believe there is either a loose pulley or on the other side of the pulley spindle is a spoke assembly that holds the basket on is broken. If you see water leaking at the spindle you have bearing and seals that have faulted. Either one of the last two are expensive to fix, if you have a home warranty that blankets your appliances with a deductible I would recomend getting a tech out to fix those problems.
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-05 error code Hotpoint WT746
how do i fix error f-05 on my washing machine
Apr 02, 2008 | Washing Machines
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
2-yr old unit is leaking
I had this problem with similiar model, the extended warranty company was out several times, replaced gaskets and many other parts. Still had the problem. The last tech replaced the upper washing arm that hangs below the upper rack, He said there was a defect where water shoots out between the mfg welded seam and shoots water at the door in the right spot to make it leak. He replaced it and haven't had the problem for about 8 months.
Nov 26, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Thomson TE1152 Top Load Washer Logo
66 people viewed this question
Top Thomson Washing Machines Experts
Harjeet Singh
highlander28
Level 1 Expert
Sue Hale
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
