I recharged the water now the boiler will not fire up. If I take the burner box cover off it works now and again, I took the water pressure back down again but no difference.
  • Marsh845 Aug 02, 2008
    it is a Vokera compact HE condensing boiler
    Sergeant:
    Champion:
  • 310 Answers
Can u tell the name and model no
Posted on Aug 01, 2008
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
I need to turn the temperature down on my Hydrotherm oil-fired burner. How do I do that?
On the front of the unit on the upper right is a grey box. Remove cover. Inside there should be a notched steel dial to adjust the water temperature.
Hope this helps.
Bob
Mar 04, 2014 | Hydrotherm Boiler, Oil Fired - PB-105/120W
Burner not quite right
You need to get an engineer urgently , there could be a flue problem , i would suggest shutting the boiler off until then
Jan 23, 2014 | Water Heaters
Pressure gauge reading zero
Hello Mark
First of all turn on a hot water tap and keep it running whilst you check to see if your boiler is firing up, if it is not then try to restart it, you should hear the flame if its running, turn your tap off then just stand by the boiler for a few minutes to see if the pressure gauge starts to rise, if it doesn't rise you will never get any hot water, you will have to add some pressure to about 1 and a half on the dial, to do that is simply turn on the water valve in the bottom of your boiler and watch your pressure gauge rise to about 1 and a half then firmly turn it off again, it looks like a small tap like the one at the back of your washing machine pipe, it's ok you will hear the water rushing in, now with your gauge at about 1 and a half and your boiler running your water will get hot
Oct 23, 2012 | Water Heaters
We needed to turn the water off at the stopcock to repair a tap and for safety we turned the boiler from all day to off. when we turned the water on again the boiler was off completely. what do we need to...
Hi the temperature control on the boiler should start the boiler as soon as you restore power to it. I don't know if you have a automatic ignition module or a standing pilot. If it is a standing pilot, make sure it is lite.You should have a temperature gauge telling you the water temp., and if it was off all day I am sure it is very cool. Do you have a drain valve on the front bottom of this boiler? If so, and you have a floor drain, turn it on as you may have gotten air in the system causing it not to fire up. If not, open all outside hose bibs/faucets and indoor faucets and let them run for awhile. If the water was drained out from the boiler to repair this tap, its off on its low pressure shut off switch. This is a safety. After bleeding any dirt or air from the system, make sure that you hear the boiler filling up with water. Once it reaches its low pressure cut off, it will fire up and start to heat the water. I don't know how large it is, but it may take some time to reach its cut out switch before it will fire again. Please keep me posted in the comment box. Please rate me on my help to you, and I thank you for this.
Sincerely, Shastalaker7
A/C, & Heating Contractor
Feb 20, 2011 | Heating & Cooling
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
I have a VOKERA 24 boiler the Linea range which was working fine until i notes the pressure was a little under 1.5 Barr. I topped it up the pressure with the filling loop every thing was fine. The next day...
Water logged expansion tank ( ruptured diaphram in tank) or wrong size tank. This caused the excessive pressure in the system causing the relief valve to open. Also, air in the system causing flow to stop, Both conditions will cause boiler go out on safety.
Sep 13, 2009 | Water Heaters
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Aug 29, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
