Question about GE Microwave Ovens
My GE microwave's keypad don't work. - GE Microwave Ovens
  • 34 Answers
The keys have gotten moisture behind them. Either unplug it and wait a day and it'll work or replace the keypad, or get a new microwave
Posted on Mar 15, 2011
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE JVM1540 microwave keypad
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still fails, you would probably have a bad door switch or mount or a bad "start" pad on your membrane keypad.
See these files first:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Once you look those over, if you still need help, please reply back with the full model number from the tag in or on your unit.
Posted on Dec 18, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: keypad not working after boiling water below
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Otherwise, the keypad may be damaged or worn out, or control unit may be damaged.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Your full model number would be one of these: JVM1540DM1BB JVM1540DM1CC JVM1540DM1WW JVM1540LM1CS JVM1540SM1SS
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 10, 2010
Richie_asg1
  • 1036 Answers
SOURCE: GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Posted on Aug 20, 2009
caroldon
  • 17130 Answers
SOURCE: My ge microwave displays a message " keypad has
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.Some dirt can accumulate and cause the tracks to short resulting in this display. Try to use heater to warm off any moisture.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Posted on Jul 25, 2011
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
GE OTR microwave model #HVM1540DN188--keypad buttons #1 thru 6 do not work.
The problem is in the keypad control board, this part is at least $97.00 or more to replace and does not include the labour.
Jul 03, 2012 | GE JE1540 Microwave Oven
Keypad 3 & 9 do not work on ge jes1290
The keypad control board must be replaced, cost can rival some microwaves.
Apr 17, 2012 | GE JES1290 Convection/Microwave Oven
Ge profile microwave jvm1870sf02 buttons don't work do i need to change the control panel frame or Bkt c/panel
You will need to change the keypad along with the control board, because they are essentially of one piece. But the part will equal, if not more than a new microwave oven.
Apr 08, 2012 | GE Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a two year old GE JVM1540 Over the oven microwave. For some reason the keypad does not respond to any touch. It just has the display panel scrolls press start but doesn't allow any action.
These units are known for this problem. You cook on stove and stream gets into keypad causing keypad not to respond anymore. The good news is keypad can be replaced, the bad news is it will happen again and the keypad costs around $125. GE will not admit to any problem, but I see this problem alot. You can get a new keypad at appliancepartspros.com
Aug 27, 2010 | GE Microwave Ovens
GE MICROWAVE - KEYPAD SHORTENED
spare keypad can be bought at repairclinic.com
let me know how this works out for you.
Benjamin
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
1,381 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
