Question about Gaggia Titanium Espresso Machine
Hi Experts, We have had a GAGGIA TITANIUM Coffee Machine for a year or so. Recently it has started to display and get stuck on WARMING UP - when we turn the machine on, OR after we have made coffee but not yet steamed, OR after we have steamed but not yet made coffee. We wait but the machine never warms up. We have descaled and we have tried ventilating after steaming. Any clues??
  • 3 more comments
  • cambyjed Mar 15, 2011
    The machine heats up and produces coffee OR steam - but not both. Doesn't seem to be a heating element problem. Sometimes the WARMING UP display comes on after turning the machine on and sometimes halfway through the process. Often we get good steam and frothed milk.
    Looks like something we cannot fix ourselves. We'll head to a repair shop. I'll take alokerdas and reyjoshua07 s comments along with me. Many thanks.
    Looks like something we cannot fix. We'll head to a repair shop. I'll take alokerdas and reyjoshua07 s comments along with me. Many thanks.
    Guru:
  • 1,833 Answers
There is a problem in steamer switch. Or the sensor around the steamer. But you cannot fix it yourself. you have to take it to a service personnel and get the switch/sensor replaced.
Posted on Mar 15, 2011
    Genius:
  • 1,157 Answers
Hi cambyjed,
If your machine has taken a long time heat up or doesn't heat up all the way it might caused by a defective electrical heating element. There are several ways on how to check this problem, either you check if there's any defective connection or check if the electrical heating element is defective. Here are some steps that you may consider to diagnose the machine.
Sometimes Espresso won't warm up due to:
1. Defective electrical heating element
2. Electrical connection is defective
3. The pressure switch contacts are oxidized
4. The heating element protection thermostat has cut it
Please try these basic solutions for the above issues:
1. If you found out that the electrical heating element is defective, please replace it.
2. Check for any defective connections
3. Clean the machine
4. Also clean the contacts or replace the pressure switch
5. Reset the heating element protection
6. Clean the connections of the exchanger and clean the circulation tubes
7. Eliminate air pockets in the hydraulic circuit. Please follow the instructions below:
a. Disconnect the electrical power supply to the pump
b. Close the water tap of the softener
c. Perform a dry run of delivery for a few minutes
d. Now reconnect the electrical power supply to the pump
e. Open the water outlet tap of the softener
f. Perform deliver until water comes out
g. Now wait for few minutes for heating
--> if you will be encountering the same issue after performing the steps above, you may need to contact a repair man to further diagnose the machine.
Hope it helps.
Thank you for using FixYa.
Gaggia titanium coffee slow coming out of machine
Not sure it will work for you but Our Bunn has a flex wire to run thru the tube weekly , and if we do not clean that tube it might take 20 minutes to make a pot where when cleaned it does 12 cups in 3 minute
Nov 26, 2015 | Gaggia Titanium Espresso Machine
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Aug 20, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
Aug 03, 2015 | Gaggia Titanium Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium blocks on display screen
The main board has failed.
Sorry no quick fix for that one
Jan 07, 2010 | Gaggia Titanium Espresso Machine
Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
Oct 30, 2008 | Gaggia Titanium Espresso Machine
Gaggia Titanium
Do you mean the brewing unit you not can get out?
Jul 12, 2008 | Gaggia Titanium Espresso Machine
Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Feb 11, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
322 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
