Won't come on
Power light flashes 3 times and shuts off. Please help.
Thanks,
Dave
  • homeheating Aug 01, 2008
    RCA D52W20B Rear Projection TV. Power light flashes 3 times but won't stay on.
    Thanks,
    Homeheating
  • 4,234 Answers
Since this is a CRT based set, there is no lamp to replace. The set is in protective shutdown. This means that a problem was detected and the set shuts down to prevent further damage. Perhaps one of the most common faults is the horizontal output transistor. If you have any experience with TVs, you might be able to fix this yourself. If you are not comfortabel working inside the set, expect a parts cost in the $50 range plus hte local labor rate for the repair.
Dan
Posted on Aug 01, 2008
  • 38 Answers
It could be a fanning problem or a lamp problem but it also might be from inproper wiring on the inside of the tv which can cause some wire to burn others making your tv not have any setup. that can be fixed by rewiring the main circuit through the power generator on the inside of the tv.
    Master:
  • 382 Answers
can you please specify the model of your tv so that we can give you more appropriate solution!!..Thank you...
  • Natesan Sabesan
    Natesan Sabesan Aug 01, 2008
    Yeah well there are "three capacitors- 2200 mf16v 22035v 33035v " which are present and try to replace these caps,which should exactly solve your problem..But if they dont solve,then try to replace the flyback..Thank you...
    Kind Regards!!...
    Sergeant:
    Champion:
  • 310 Answers
Just turn off and turn on next day.....
It will work.......
  • 6,487 Answers
What's the brand and model of this unit??
  • Mark Gil
    Mark Gil Aug 01, 2008
    This can be a problem with the lamp that ,ay need a replacement because this is a symptom of a bad lamp..
    Good luck.....
  • Mark Gil
    If this unit has a fan inside it maks sure those fan are working fine , because this can be just an overheating problem....
What does a flashing red light on a jazzy power chair mean and it wont move
Need to count the number of flashes and consult your user manual. There is usually a section there that explains Fault or Flash Codes and will usually lead you to the problem.
If your still struggling please just message back
Thanks Dave
Nov 09, 2014 | Pride Jazzy Select Power Chair
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Blinking lights
You have a number of small LED's in an arc that form your battery display that will be flashing. How many are flashing as this represents the fault identification. If you can tell me how many i can help to diagnose the fault for you. Thanks Dave
Jun 11, 2013 | Shoprider 6 Runner Power Chair With 14"...
I've got a Palmer twosome, it is flashing either 3
Dave I think that is an indication of a brake problem either an open coil or other issues with the brake without replacing the brake assembly the scooter will not operate sorry Contact the provider that sold you your scooter to see if he can get the part for you Hope this helps
May 07, 2011 | Health & Beauty
Power light is flashing 3 times consecutively. When hitting the power button the fan comes on then shuts back down..then starts flashing the red light again..I've recently bought a new lamp and installed...
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
Aug 13, 2010 | Sony KDF-50E2000 50" HDTV
TV turned off and now the power light blinks three times
Very common problem. 3 blinks means the convergence circuit has failed . Heres a link to the repair kit for your model which contains both convergence IC and the feed resistors and the kit has step by step instructions with pictures so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    I have a 53 inch wide screen Panasonic that is roughly 5 years old. It was working fine until I now hit the power button and the light stays on and then the picture comes on for 5 seconds then the TV...
    whatsthe model number of your panasonic. Most panasonics mean convergence failure when the led blinks 3 times. Please respond to this post with your model number and I will post the correct ICs for your model and where you can get replacements with free instalation instructions
    Jun 27, 2008 | Televison & Video
    WD-62725 Need to reset to start
    Good Day;
    When TV will not turn on press the menu & input buttons on TV's panel, hold for 5 seconds. Count the blinks, eg; blinks 2 then pauses then blinks again. It should do this 3 times.l With that information respond back.Or the d-board is bad.
    Good Luck.
    Apr 21, 2008 | Mitsubishi WD-62725 62" Rear Projection...
    Laptop Won't power up :(
    remove battery pack and cleaned battery terminal
    Mar 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
