Question about RCA TruFlat 27F520T 27" TV
The unit turns on then powers off within 30 seconds?
  • 34 Answers
There is a shortcircuit in the TV and it needs to be repaired.
Posted on Mar 15, 2011
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
My ps3 says that the hard disk file is corrupt please tell me what to do
You can always do a factory reset on the unit. In order to do this, turn off the machine. When you turn it back on keep holding the power button down for about 30 seconds while it turns on. It will beep once right away (within 3 or 4 seconds when it resets the video display output) continue to hold the power button down until you have heard 3 beeps. This should reset the unit to factory settings and should come up with a prompt to reformat the hard drive. The downside is that you will lose all files you have saved on your machine.
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
How do i get unit to go in deforst
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ps3 freezes and shuts down after 20 seconds after powering on, what could this be?
I have the same problem. When it is turned on it shuts down within 30 seconds and I need to disconnect the power cable again before it can be turned on (and again shuts down after some 30 sec.)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
The unit beeps
I am getting these directly from the user manual (available here: http://www.apcmedia.com/salestools/ASTE-6Z7VAQ_R3_EN.pdf)
Issue: On Battery - UPS is supplying battery power to the load connected to the Battery outlets.
Visual Indication: Power On LED - ON (off during beep)
Audible Indication: Beeping 4 times every 30 seconds
Stops When: UPS transfers back to Power On operation, or when UPS is turned off.
- OR -
Issue: Sleep Mode - During On Battery operation the battery power has been completely exhausted and the UPS is waiting for utility
power to return to normal.
Visual Indication: None
Audible Indication: Beeping once every 4 seconds
Stops When: Utility power is restored, or if utility power is not
restored within 32 seconds, or the UPS is turned off.
All other issues are CONSTANT tones, which you did not specify, or there are no audible tones associated with it.
Apr 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
I have a denon 1909 reciever.
The unit is going into protection mode. This means that a problem was detected and the unit shuts down to prevent further damage. Examine the speaker wires to be sure that they are not crossed. If they seem OK, remove them and attempt to turn on the unit. If the unit behaves the same, then the problem is internal to the receiver. The most common cause of this is shorted output transistors. These are relatively inexpensive. Expect a parts cost in the $30 range. Add in the local labor rate for the entire repair cost. Dan
Jun 06, 2009 | Denon Audio Players & Recorders
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Display
try checking on the settings maybe you accidenally change the lighting schemes in your unit.
Oct 18, 2007 | Pioneer DEH-P6900UB CD Player
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
