Question about Cameras
Hi im just wondering which connector to put my power supply to and would a 240v to 12v inverter supply the right amount of power
    Problem Solver:
  • 6 Answers
Check the input voltage number on the power supply. Many cameras take 110 - 240 volts. If that is the case you do not need an inverter ... if the input specifies a voltage such as 110 OR 220 then that is the voltage you must have from your inverter. If you are stepping all the way down to 12 volts then the output voltagefrom the inverter must match the input voltage for the camera. It is best to use a recepticle adapter for your power supply and make sure the power supply input and the external electrical supply match or the external supply is within the range specified on the power supply..
Posted on Mar 15, 2011
Fix an inverter that has two blown fuses, are they 12v or 240v how do l repair them
Both, :) you should have glass fuses and when you buy them they will say 12 v 20 amps, But thats about the same as a 110 v at 2 amps maybe a little less, Look for what you have by reading the side of the fuse for the right amps.
Dec 04, 2014 | Inverter Electronics - Others
Can a 12 v supply be used for ferg.f1604levd straight from a 12v battery
a 12V battery from car??
in cars battery are actually between 14V(fully charged) and 11V(empty)
else i don't know but the best way to be sure is using a regulator (this for example)
Nov 21, 2012 | Computers & Internet
Can i connect my tele in mt caravan on 12v
Yes. Either by using a 12v dc tv, or if it uses 120v/240v ac by using an inverter on the 12v dc supply which ups the voltage and converts to ac.
Jul 14, 2011 | Televison & Video
Have an electric run pellet fire what size car or truck battery to run for 8 hours 520 watts
You'll need a 600W (Minimum) 12 to 240V Inverter as in the link below.
http://www.powerinverter.co.nz/16-10-12v-to-220v-power-inverter-600watts.html
As for the battery you will need 44Amps of Battery Power for every hour you want to run the equipment (this is without any losses from the inverter on inefficiency from the battery). You would therefore need as a minimum 2 x 200Ah 12V Batteries connected in parallel for something like your 8 hour duty. You'll also need them to be this sort of size so that they can supply the high current for a long duration. i.e. a 44Ah Battery would not supply 44Amps for 1 hour.
Hope this is OK and please leave feedback.
Cheers
Andy
Apr 30, 2011 | RaidMax ( RX-520XP) 520-Watt Power...
Hi, im teddy from kenya. Im an electronics technician working on tvs. I have sanyo lcd tv model: LCD-47XR1 which is switching on but the display is black. please assist. thanks in advance.so far i have...
hi.. hope this help...try to check the power inverter that supply the screen lighting's. it should have 12V output for 24" below or 24V for 25" LCD and above....pls. rate and vote..good day
Feb 15, 2011 | Sanyo Televison & Video
Q7 12V socket Inverter Wattage Question
no you need to know the wattage of the item you are trying to power. To find the wattage of the item you are trying to power is simple. Some will say directly others will give you the amps (ie. .5amps, 1.2 amps.) you take the amps and multiply it by the volts that it says. All this info is on the item you are trying to power with the inverter. The answer is what it will take to power that item. example .5amps x 240v = 120 w so in this instance you would need an inverter that would produce at least 120w so in this case the 150w inverter would work. Good Luck, have a grt day
Apr 01, 2010 | 2009 Audi Q7
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Dec 09, 2009 | Audiovox FPE3206 32 in. LCD Television
Howtowire 2 12v batteries to an rv?
wire one hot lead to one battery and one neg lead to the same battery
then wire second battery to the first one
your inverter lead goes to the positive post of the first battery
Nov 23, 2009 | Interstate Batteries BPS 120/240V 7200W...
Power supply for westell 327w
Replacing a power supply for the westell 327w is apparently a tricky thing. The official numbers are: Input: AC 100-240V 50/60Hz 21W Output: DC 12V 1000mA You should definitively read the last posting in this thread and see what this guy found out. If you can, try it! A lower voltage does not so any damage, but make sure the polarity on the connector is right. Very interesting! http://www.dslreports.com/forum/r20265443-power-supply-327w-what (Sorry - but fixya does not provide weblinks right now, so you have to copy the whole line and paste it into your browser.) If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 09, 2009 | Computers & Internet
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
