Question about Dell Vostro 1500 Notebook
Have dell inspirion1525. Screen is black. By holding down fn key and start key i get flashing lock with 9 and blue lock wih an A and blue lock with a down arrow. What do these mean?
    Scholar:
  • 80 Answers
Well the Flashing "lock with 9" is Num Lock, the "blue lock with an A" is Caps Lock, and the "blue lock with a down arrow" is Scroll Lock. Hope that answers that question.
Now for the screen being blank usually means there is an issue with either your LCD display or an issue with the laptops video card. Plug in an external monitor and boot up the laptop if you still get a blank screen then there is an issue with the laptop's video card. If you can see your screen on the external monitor then there is an issue with the connection of the LCD displayon your laptop. You can try ifxing it your sleve by opening up the laptop and making sure the connection is firm or you can take it somewhere to get it fixed.
Please rate if this helps
Posted on Mar 15, 2011
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
After being turned on the screen goes black and the lock key with the number 9 is illuminated ablove the keyboard
I had that happen to me with my Dell as well... If you're comfortable with taking a laptop apart.. you'll need to detach the screen ribbon, clean it with rubbing alcohol, and then reattach it. This should do the trick..
Jun 02, 2009 | Dell Latitude D400 Notebook
Fn+f2
fn+f2 means your pressing two keys at once
the function key (fn - usually a different color - maybe blue - than the letter keys) and the f2 key
hold down the fn first then the f2 - look for the fn on the lower right or left next to Ctrl keys
Mar 30, 2009 | Dell Inspiron 6400 Notebook
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
When i use my keyboard it registers the blue symbols on the keys,
Sounds like you've got the "Num Lock" turned on.
Check the keyboard for a key that has a LOCK icon.
It's usually on the Scroll key.
Let me know if that fixes the problem otherwise I'll suggest something else.
Best of luck!
Feb 26, 2009 | Dell Inspiron 1501 Notebook
It is better to run the dell diagnostics, when you see the dell logo keep on tapping f12, then choose utility partition and do an express on your system.
Nov 01, 2008 | Dell Latitude D400 Notebook
Blue keys 2
If you press the Fn and Num Lock at exactly the same time, it usually won't work. Hold down Fn key first, then press Num kock. See if that works.
Apr 04, 2008 | Dell Latitude D600 Notebook
Dell Laptop - Keyboard "Fn" is causing problems!
I think it is not the Fn key but the NumLock that is activated. Look for the key labeled NumLk , this is the number lock. Also check if the light on the notbook with a number (usually number 1) is on. If it is on, yo must deactivate the numlock by pressing it again. It works in toggle mode. Sometimes the numlock is activated together with the shift key, sometimes with the function key.
Jul 06, 2007 | Dell 0Y3740 Keyboard
Dell Vostro 1500 Notebook Logo
456 people viewed this question
Alun Cox
