Question about O2 Xda IIi Smartphone
I have an o2 xda lli but the problem is i cant charge thru main charger like thru ac adpter but the thng is i cn charge it thru usb in my laptop what can i do coz i cnt open my laptop evrytym my fon is empty ryt..pls hlp me wat cn i do.ders is no prblm wit my charger.coz thats the exct same cord im usng to my laptop.and one thng when i chrge it usng ac adapter its shwn it the screen its chargng but the percent is still 0% evn i chrge it very long time.
Code de veroyage
Posted on Nov 29, 2012
  • sizar_n
    sizar_n Nov 29, 2012
    comment
honey2509
  • 146 Answers
SOURCE: O2 XDA II Mini *.Cab Fine Not working
it seems the .cab files you are installing on your phone...they are not ment for your PDA's OS....plz use the sutable cab files for WIndows Mobile 2003
all the best
Posted on Jan 31, 2008
honey2509
  • 146 Answers
SOURCE: O2 XDA Orbit circuit diagram required
log on to http://xda-developers.com i hope this will solve your problem
all the best
Posted on Feb 01, 2008
L512Yan
SOURCE: O2 Xda stealth shows the welcome screen only .Stuck !
Before you start pull out the memory card maybe very full and causing slow load/lock up, then startup bearing sometime its very slow if unsucessful then pull battery out and try again !
Hope this helps!!
cheers
YT
Posted on Aug 12, 2008
SOURCE: o2 xda 2 mini pocket pc usb connection problem
how i get my o2 xda ii mini drivers?
Posted on Oct 24, 2008
  • 9 Answers
SOURCE: driver for O2 xda orbit
All you need for this phone to get it working on a Windows Laptop (Windows XP or Windows Vista) is the Microsoft ActiveSync 4.5 software (for windows XP) which you can download from this link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141&DisplayLang=en
If you use Windows Vista then you can use the Windows Mobile Device Centre to achieve the same thing.
Posted on Dec 29, 2008
Tip
I used a standard 3310 type Nokia charger. The charging plug has a small hole...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on May 21, 2008 | T-Mobile MDA
Cant turn on
I advise you to buy a charger with the current and voltage ratings provided on the battery with the USB output and connect the phone with the data cable to get it charged.Or you can directly connect to the computer to get it charged.
Jul 05, 2009 | O2 Xda Atom Exec Smartphone
My o2 xda atom doesn't charge. i don't know if its the battery.
I think the problem is your battery... and you think that your battery is OK then you can try charging it the computer through USB.
Nov 13, 2008 | O2 Xda Atom Exec Smartphone
IC Power
1st check yur charger if yur charger is ok then check the charging socet if both ok then change , resold , or reball the charging ic it will charge properlly
Sep 19, 2008 | O2 Xda IIs Pocket PC
O2 Xda Exec
It appears it has something to do with the flash continuely trying to operate. When charging (Red LED blinking in quick succession) the flash can be conitnuely seen to be operating.
Doesn't fix the problem but I think this is the cause
May 26, 2008 | O2 Xda Atom Exec Smartphone
Dead Unit
if you are charging from the computer usb it wont work you will need to buy a wall charger from ebay or somewhere and the phone will fire up again hope this helps
May 09, 2008 | O2 XDA Mini S Smartphone
I cannot turn my pocket pc on ?
Dear lmd0990,
I cant tell u how but I can show u how to fix it coz Im not good in theory but quite ok in practical ways so how? Im in Shah Alam so if u want me to check ur o2 just drop by my house and Ill open ur o2 in front of u and u can watch and learn. Call me b4 u wanna drop by k. My no is 019-3671077.
Apr 12, 2008 | O2 Xda II mini
Not wroking
Apparently if you let the battery go completely flat it won't charge via USB and you'll have to use a proper plug in mains charger.
I've just had the same problem with mine and I've been searching the house high and low for the charger!
Mar 19, 2008 | O2 XDA Mini S Smartphone
O2 Xda IIi Smartphone Logo
83 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
