Question about Air Tools & Compressors
I had a 92 tercel alternator on my ae92 rolla.I just put in a new one now the brake and battery lights one the gauge turn on when the ac compressor activates.WTF? ???? anybody??????
  • 90 Answers
Um that's a tough one without actually looking at it. just re-check your electrical wires and make sure they're re-connected properly and check for any damaged wires, including ones that may be melted together.
Posted on Mar 17, 2011
I have a 92 nissan sentra and the battery/brake light comes on after about 10 min. driving if i'm not doing freeway driving. Then will go off after a minute or so of freeway driving and stay off. Then...
check brake globes are ok could be filament broken that is touching and then not touching inside the globe. Also check brake fluid level in reservoir in engine bay . Could be low brake fluid may have a problem with the brake master cylinder .
Aug 04, 2017 | Nissan Cars & Trucks
04 sedona belts moving slower when ac turned on and brake and battery light come on
is your car at an idle when the a/c is engaged it takes power to run this circuit your engine will slow down. most cars have a sensor that will increase you idle when a/c is engaged. this also compensates for the added drain on the alternator
Jul 07, 2012 | 2004 Kia Sedona
Toyota tercel 1991...getting poor gas milage...eating it up fast. New plugs and wires....not sure of the fuel pressure...could this be the fuel regulator?
First thing to check... operating temp of engine.. does it take forever to warm up or a long time for warm air to come from the heater? If so you have a stuck open thermostat and this can cause the engine to never reach proper operating temp.. and it will consume extra fuel. Many don't notice at this time of year.. between warm afternoons and cool mornings.. spring..
I doubt you have a problem in fuel delivery.
Of course all other things should be checked.. tire pressure, and brake operation.. and any accessories on the engine such as alternators and ac compressors.. lastly do a coasting test to check alignment and braking.
Best of luck
Apr 24, 2011 | 1991 Toyota Tercel
92 suburban ac light blinking tried to add freon but pegged the pressure gauge when hooked up to the low pressure port
My ac light is blinking, and the ac compressor clutchpulley is not engageing. Its also blowing hot air
Apr 13, 2011 | 1992 GMC Suburban
I turned on my ac in my car and my car made a loud squeaking noise, then my battery light can on my dashboard...need help!
It means that eighter the ac compressor belt needs to be replaced or the ac compressor beearing needs to be replaced,, your alternator and ac belt are on the same pully,, if eighter the belt or beering is bad,, when u switch it on,, it will squeek and put extra load on the alternator so it wont charge propperly... causing the light to come on.. replace them and you will be fine..
Jun 24, 2010 | 2005 Dodge Stratus
1996 toyota tercel air conditioner will not work
Hello, and welcome to FixYa. Let us try to help.
Yes, you read correctly; if the refrigerant charge is low,or the refrigerant has leaked out, the AC compressor will not activate. Pressure switches built into the system inturupt the power to the AC clutch if there is insufficient system pressure.
I would suggest taking the vehicle to a qualified garage, and have the service tech there hook his set of 'AC Gauges" to the car. After he does that, he can tell you if you need a partial charge, of if you system is empty. I would def recommend the car be checked with the AC gauges; as adding refrigerant to the system without knowing how much is currently in it can damage the compressor.
Thanks for choosing FixYa for advice!
Mar 25, 2010 | 1996 Toyota Tercel
IDLE problems when I turn on the AC. Electrical power seems to fluctuates when the car is stop sign/light or other when i have the AC on. Check it the other day, started it up, disconnected the battery,...
alternator needs good battery to keep SCR in the regulator on if it is loaded it will shut down. this will happen when you try rolling window down or rear defog will load up the system. When the truck is running and battery is hooked up the vehicle should run at @700 RPM at idle and when A/C compressor is commended on it should idle up to @1000 RPM and then back down to @700 RPM when compressor cycle off again. But if the system almost stalls then the battery and alternator should be changed together, A bad battery will damage a new alternator and a bad alternator will damage a new battery.
Oct 07, 2009 | 2006 Chevrolet Trailblazer
Alternator , voltage regulator, alternator fuse ?
the reg is eathier in the alternator or in the front of the car under the hood somtimes by the lite
Mar 25, 2009 | 1989 Toyota Tercel Liftback
Wont start
SOUND LIKE IT MIGHT BE DODGY ALTERNATOR YOU CAN BUY A ALTERNATOR TESTER FROM HALFORD. AND CHECK ALL CONNETION FOR WERE PARTICALLY THE BATTERY CONNECTION
Jan 27, 2009 | 1986 Toyota Tercel
AC dask board signal
Replace the A/C compressor revolution sensor, bolted to the side of the compressor, unless the connector was inadvertantly left unconnected. This is the only reason the AC light will blink.
Aug 31, 2008 | 1995 Toyota Tercel
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
