Question about LG 32LH20 32 in. LCD HDTV
I Have LG 32LH20R LCD TV How to connect Headphone & Use USB (Which Video Format) Pls. know me...
SOURCE: how can I use my lg lcd tv model m1994a for my ps3
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Posted on Nov 22, 2009
Testimonial: "ok!!! it is very much helpful...I solved my problem already using this steps...now I can play my ps3 games by my LG lcdtv 19 inches..."
  • 32 Answers
SOURCE: no audio out on hdmi with desktop
Chances are your desktop doesn't support audio through HDMI. Try to find a spec sheet for the unit you have, an upgrade may be possible
Posted on May 27, 2010
budmrtn
  • 11361 Answers
SOURCE: on connection of pc to television( LG 42LG50 42
You need to lower your PC video resolution to the native resolution of this TV. It is too high for the TV to display.
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 21, 2010
  • 8457 Answers
SOURCE: My new LG LCD TV
Tries it with other USB memory sticks?See,if it could be that memory stick have problems.Tries it with other HDMI hub?
Posted on Dec 06, 2010
SOURCE: I have a LG LCD TV, I connected my laptop to the
radio shack
Posted on Feb 11, 2011
No sound from my LG HD TV to my Harman Kardon receiver
Hi!.
i want to connect my akg t 912 headphone with Sony LCD. The audio output from setup box is attached with the Home theater and not directly to LCD TV. Suggest me the way to get the setup box audio output to AKG wireless headphone.
Jan 02, 2013 | Harman Kardon Audio Players & Recorders
I have a 32LD450 LG TV it will only show picture or music options from usb no movies??
LG 32D450 LCD TV doesn't support video playback from usb. The USB 2.0 input of this particular model can only read jpeg format (photo/snaps) and MP3 format for music playback. please click the link below and see the technical specification and USB input.. http://www.lg.com/us/tvs/lg-32LD450-lcd-tv
Apr 17, 2012 | LG 42LC2D 42 in. LCD HDTV
How to use usb?
you can play video or mp3 in usb input in your LCD TV , using usb flash drive
be sure the video you put in your flash drive is in AVI or mpeg format.
Aug 27, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Cant get any sound on tv
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two separate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video + sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | HP Compaq Presario C700T
Connect Logitech 2.1 to TV
i dont know how ur tv does not have a earphone jack i wonder now a days how they make such tv's , pls try to take sound from audio LR if it helps other wise no hope to get sound on speakers sorry pls try to find in manual if there is any hidden headphone jack some where see in manual
Feb 25, 2009 | Logitech X-530 Computer Speakers
Connect headphones to lg scarlet 32inches tv
ya..you can connect your headphone to the
LCD tv.It will be available on the back of the
tv.The port will be available.
check this out..
thank u..
rate me..
Feb 24, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
LG 32LH20 32 in. LCD HDTV Logo
415 people viewed this question
Computer Repairing
Computer Repairing
