Question about Car Audio & Video
Can u tell me where the level of the gearbox oil must be and how much oil must be used
    Problem Solver:
  • 10 Answers
Gearbox for tranny?
Posted on Mar 16, 2011
2010 Peugeot 207 gearbox drain/filler/level bungs
The drain plug is situated on the final drive casing at the rear of the transmission (plug may need a square or hex drive wrench).
There is no level plug - the correct qty of oil must be measured and then poured in.
If Petrol 1.9 ltrs, diesel 2.0.
The oil is 75/80w.
Jan 19, 2014 | 2008 Peugeot 207 CC
Tip
How to change (check) AUDI transmission oil
Transmision oil for Audi A4 (1.8, 1.8T, 1.9 TDI):
Manual gearbox (5 speed):
- Capacity = 2,25 liters
- Specification: Gear oil SAE 75 W 90 (synthetic oil)
Part number G 052 145 S2 (1 liter)
- To check oil level, unscrew oil filler plug placed on the left side of the gearbox in front and near of transmission axle, using an Allen 17 mm key.
- Check oil level with locally manufactured tool, e.g. a piece of angled wire.
- Specification: oil level 7 mm below bottom edge of oil filler hole.
- Install oil filler plug, tightening torque = 25 Nm.
on Dec 19, 2009 | Audi A4 Cars & Trucks
How do I put gearbox fluid in ? Where is the level glass? I have a 1997 mitsubishi magna
Gearboxes usually have no oil dipstick / looking glass. On the side of the gearbox there's a bolt with (brass) washer. This is where the gearbox oil goes. To check the level is to stick one finger in downwards, when there's no oil at this level its usually too low.
On the bottom of the gearbox there's a similar bolt with washer to drain the old oil. The bolt can be magnetic - and can look a bit like a mushroom. Tiny particles from the gears stick on there - this is normal. Large bits of metal can be a cause for concern.
Always use the specified gearbox oil - wrong oil makes changing gears hard.
Jul 05, 2011 | Mitsubishi Galant Cars & Trucks
My gear stick keeps jumping when in gear.
Hi sheila? this is normally caused by lack of oil in the gearbox. make sure the gearbox oil level is ok before doing any thing els. In the fron of the gearbox there should be a plastic lead which can be unscrewed to inspect the oil level. the oil level should be level with the base of the hole. If oil comes out when you unscrew the lead that's ok. If the oil level is ok then the gearbox may be worn out.
May 21, 2011 | Renault 18I Cars & Trucks
Light on on dashboard:
The light refers to the automatic gearbox. It is a general warning that there could be some sort of problem. It could be anything from low oil level to gearbox failure. Get a good mechanic to service the transmission as it might be something simple like low gearbox oil.
https://www.mynrma.com.au/cars-and-driving/car-servicing/resources/what-do-my-dashboard-warning-lights-mean
Jan 25, 2018 | 2005 Suzuki Swift
1995 Yamaha TY250z how do I check the gearbox oil level and what type of oil should I use?
there is a screw on the side of your clutch cover that is your oil level screw. dont even use it as its not reliable... beside the oil fill hole it will say how much oil goes in. on my 03 yz 125 it takes 650cc yours will tell you. Drain your oil and put how much it says in. I use rotella t oil from walmart its in a white quart jug. Its the same oil the pros use and its cheap as well. dont go spend a fortune on "good" oil when rotella t is just as good.
Jul 10, 2010 | 2003 Yamaha YZ 250
While removing the CV from the car there was a lot of Oil coming out of it. would that be normal. it smelt like motor oil and looked it as well.
you must have pulled the whole axle out.finish what you started to do,then put axle back in,make sure circlip is clicked in,then refill g/box/diff to correct level.
Jul 06, 2010 | 1997 Mazda MPV
Manual gearbox filler
according to my book,the speedo gear,on top of g/box,is used to check oil level.pull speedo cable out,youll c the oil level marks
Jul 01, 2010 | 1991 Mazda 626
Gearbox oil level on CBF 150
You have nearly answered your own question, if you have a dipstick, There should be a small mark on the lower end which will tell you not to go past
Feb 06, 2010 | 2006 Honda CBF 250
Transmission
Well, I'm not sure. Try changing the gearbox oil and try again. I saw on the other postings that most Audi gearbox problems pointing to a gearbox swap can be solved through oil change. I just had mine changed and it has reduced sluggishness and shuddering at low temperatures (from cool engine). It's a special gearbox oil you need to get from Audi, by the way.
Jun 14, 2008 | 2001 Audi A6
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
