Richmond 5vp40e-1p a. It will light, burn for about two seconds, then the gas valve clicks off. Sometimes when it tries to relight, it clicks but fails to light. It will relight no later than the second try, but then it turns right back off again. The sparker seems to be fine. My vacuum switch is working. Exhaust fan is working. I have a good LP supply. It seems like the gas valve is malfunctioning.
  • 87 Answers
SOURCE: When turned on, lights come on, but will not blow...
First off, I dont think you caused this problem by vacuuming the unit. It is possible that you did not leave much time before restarts but you then said you tried leaving it off for 5 minutes which should be adequate enough. f you let the unit set for a couple of hours before a restart that should be enough time for the compressor to cool down to ambient temp. I would then try restarting the unit, if it works leave it on for a while and make sure it is producing enough cooling. If there is no change in the situation I would suggest that it would need to come back out of the housing and check that the compressor is receiving voltage to it. It is possible a start capacitor or relay is the cause of the problem. If it started first time I would suggest it is worth having it checked by a professional as it could be the charge or the starting devices. First off though let it completely cool down and try again. Hope this is of some help.
Posted on Sep 15, 2007
  • 143 Answers
SOURCE: Fan runs, but when compressor
The compressor has a safety switch under the cover where the wires connect to it. That's what is kicking out. You should check the capacitor connected to the start winding. Check the wires where they connect to the compressor. A burnt off wire for the run terminal will cause these symptoms. If that's all good, it's being fed correctly on all 3 terminals, the compressor has stalled and will probably never start again. You can try a "hard start" kit, but not on a Scroll compressor (read the label). They aren't designed to survive that.
Posted on Jul 27, 2008
  • 85 Answers
SOURCE: Amana Gas furnace, Air Command
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Posted on Dec 02, 2008
SOURCE: Slow gas on Carrier 8000 58TUA?
Saw this happen one other time where the regulator at the outdoors gas meter was faulty and not supply the correct gas pressure. You may need to have the gas company come out and check the pressure at the meter. Also, check to make sure no other gas appliances are running..ie..water heater, gas logs, stove, etc. and then start up the furnace and see if it will start up properly. This would also indicate a problem at the gas meter...ie..gas pressure.
Posted on Dec 21, 2008
  • 306 Answers
SOURCE: Rheem Furnace sometimes takes a couple of ignition cycles before
Try cleaning the flame sensor. It is located right besides the last burner. Looks like a thick piece of wire. Take steel wool and gently remove the carbon that has built up. Should only take 4 or 5 strokes. Let me know how it goes after that. ken
Posted on Dec 23, 2008
Why won't control knob on water heater turn to off or pilot position so that I can relight
It usually needs to be pushed straight down, or into the valve body, if it is on the side.
Mar 26, 2017 | Water Water Heaters
Where is temp. control ?
On the gas valve at the bottom of the heater.
Feb 26, 2017 | Water Heaters
Richmond gas w/htr. light pilot and main burner 15 seconds both flame out...relight pilot..it'll stay on five minutes .flames out..new thermo coupler
Make sure the thermocouple is deep into the blue part of the flame. If it is good, then the only part left is the defective main gas valve.
Sep 08, 2015 | Water Heaters
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Propane water heater high limit switch keeps kicking out
1) What brand and model water heater?
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake screen using compressed air or feather duster.
With AO Smith, craftmaster, state, reliance, american, kenmore, whirlpool, the air intake is located on bottom of heater. Rheem, richmond, ruud, GE, Bradford white, the air intake screen is located under combustion parts.
Water heaters today require plenty of fresh air. If air intake gets clogged with dust, then combustion byproduct moves up pipe too slowly for amount of fuel being burned, and this overheats combustion chamber.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Add a comment with more information
Dec 13, 2012 | Water Heaters
I have an empire heater and the problem that I am having is that when the valve is turned on high or any setting, the flame burns for a few minutes then goes out. It will not stay burning, we have to...
Have you replaced the thermocouple? Have you cleaned the Pilot? Do you have a strong pilot flame and is it touching the thermocouple? Sometimes if you don't have a good strong pilot is that when you turn the main gas on it pulls the pilot flame away from the thermocouple and cools it off so it drops the signal. Check the gas pressure should have 10 to 11 "WC of manifold pressure.
And you could have a bad gas valve. Hope this helps.
Jan 02, 2011 | Sunbeam Heating & Cooling
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My gas oven, Kenmore model 362.7271192, will not work. The stove works just fine, but the oven will not get hot or light. How do I relight the pilot light, I don't even know if I am looking at the right...
There is not a pilot on this range. There is an ignitor and safety valve. Sometimes you can see a burned out ignitor and sometimes you will have to use a meter to check the voltage and continuity of the ignitor and valve coil.
Eric
Jun 29, 2009 | Kitchen Ranges
Heating & Cooling Logo
235 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
