Question about Conspiracy Shadow Little Ones Pegs Bmx Bike White
How to put the pegs on? - Conspiracy Shadow Little Ones Pegs Bmx Bike White
  • ryan2villopo Mar 16, 2011
    O ok thanks I saw a lot of posts on like you need to do something about the anti spin or whatever before you put them on, but thank you this post was very helpful.
    Problem Solver:
  • 16 Answers
You need to have a BMX bike with a threaded axle. A bike with quick releases will not work.
The first thing you're going to want to do is go ahead and loosen the bolts on that side of the rim, take the bolts completely off, along with your spacers, pull them off and then you'll slide the peg onto the axle. And you're going to have to have an extension to get into the peg. The easiest way to get the peg on is to take it, put your bolt, your washer and then slide your peg into place on this, or you can put it on there and then you just slide it on, and then tighten your bolt back down, and that will hold your peg into place
Posted on Mar 16, 2011
How do you wind the bobbin
Most bobbin winding procedures are very generic. There is a small peg on top of the machine and a lever to snap the peg against or the peg itself moves toward a stationery lever. Leave thread on machine like you would begin sewing but u thread the machine. There should be a thread holder of some kind on top to run thread through to hold tension. Wind thread a few times around bobbin and put bobbin on the peg on top of machine. Push lever toward bobbin peg or peg toward lever (whichever moves) and arrow by peg should show which direction thread will wind. Then push pedal and away you go...hope that helps.
Feb 11, 2015 | Sewing Machines
I need game rules for 1978 Milton Bradley "Knock Out" game
So. I played this game years ago, and just pulled it out of my moms closet of games. Anyway, its similar to Othello, if you've ever played that. Start with putting pegs into the inner circle/hexagon, with every other peg facing opposite directions. Then the first player puts one of his/her pegs into the game, trapping their opponent's peg between theirs, and then pushing out the trapped peg and replacing it with their own. Once the board is full, the player with most pegs in it, wins. You can only push out pegs that are between the one you play and existing pegs from previous play.
Dec 12, 2014 | Milton Bradley Toys
Hubs screw bit is too short for pegs
The "hubs screw is called an axle, and you did not really ask a question. Unless you want to depend on the pegs to hold your wheel on you will need to get a longer axle and take apart the entire hub to replace it.
Feb 09, 2018 | Mongoose NQP Bmx Stunt Pegs 10mm Black -...
I took the pegs off my son's mongoose outer liit freestyle bike (20") and now cannot figure out how to put them back on. I am not sure what to do with the silver washer?????
The silver washer will go between the frame of the bike and the peg. Then the nut for the wheel bolt will go into the peg and screw on from the inside of the peg. Unless they are solid pegs in which case you will put the washer on first still and then screw the peg on as if it were the nut itself.
Aug 20, 2011 | Mongoose 20-Inch Gravity Games BMX...
My right side foot peg shaft is loose. How do I tighten it?
If you are talking about the front foot peg. Take the screw that holds the peg to the mount out. Inside the mount you will see an allen that tightens the mount to the shaft you will need to tighten this allen. Then put the peg back on and your done.
Apr 06, 2011 | 2006 Harley Davidson XL 883C Sportster...
How to take off and put on a new foot peg on yamaha r6
get the correct size allen key,undo the footpeg bolt,remove bolt,pull peg out,be careful not to lose the spacers on each side of where the peg fits to the mounting point,and be sure to line the spacers correct the little holes go over the bearing on the peg to keep them snug when not in use,(rear peg only)rider peg s dont have this on them.
Jul 10, 2010 | 2003 Yamaha YZF-R6
How do i wash the cover of the peg perego atlantico
It shouldn't cause any problem if you wash it alone. If it isn't extremely dirty I'd just put it in the bath tub and rinse it out with some liquid soap and hang it up to dry.
Sep 26, 2009 | Peg Perego Atlantico Classico Stroller
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
Brakes and pegs
There is two ways to put the pegs on.
1. they screw on th the threads of the wheels where it mounts to the frame.
2. If there is just a hole in the peg you have to remove the nut where the tire mounts to the frame put the peg on then put the nut back on the wheel. You will need a long extension for your socket for this method.
Good Luck
Dec 21, 2008 | Razor Fz 2000 20-Inch Freestyle Bike
Cant find the charger for my peg perego battery
I would use the specific peg perego charger. I had a neighbor who used a different one and he ruined his battery.
You can purchase them at this website I found http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
Hope this helps
Dec 02, 2008 | Peg Perego 12 Volt Rechargeable Battery
Conspiracy Shadow  Little Ones Pegs Bmx Bike White Logo
144 people viewed this question
Top Conspiracy Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Conspiracy Cycling Expert? Answer questions, earn points and help others
