Question about Sony VAIO VGN-UX280P Notebook
Tighten the resistance at the hinge of the screen of the Vaio laptop
It has gotten to the point where if it is a little too far back from vertical, it will just slowly head down. I see some rectangular rubber covers over something at the hinge on both sides and wondering if they cover screws that can be used to adjust. It is a VGN-AX580G
  • Anonymous Mar 18, 2014
  • 2,028 Answers
On most models the hinges are a pressed in, pressure brake type hinges, and when the hinge start getting worn to the point of not holding the screen, then they can only be replaced in order to fix it. You can sometimes get away with replacing just one. On some models there are screws on the hinges that come loose that can cause this. The screws aren't for adjusting, they are basically just set screws. You won't which is the problem know until you take the covers off. Most likely you're going to have to replace the hinges. Try Ebay for the replacements.
Posted on Aug 01, 2008
Yes. Strip down the laptop and screen. The hinges will be exposed and they can be tightened up. Use care because if too tight, they will break the plastic case.
Dec 26, 2013 | Sony VAIO VGN-UX280P Notebook
Sony vaio z2 loose hinges
Laptop hinges cannot be tighten, they have to be replaced.
Check out this WEB site.
Replacing a hinge, or both of them, isn't very tough.
Aug 11, 2012 | Sony VAIO Computers & Internet
My B120 display will change to all vertical lines. when I bend the screen area back a little, the display returns to normal.
Reseat the video cable connection under the keyboard, and tighten all the screws on the chassis that are related to the LCD hinges (LCD ground is thru the hinge and if screws come loose, the ground get weak.) also inspect the LCD cable where it goes thru the hinge cover assy, that is were you are likely to break a wire.
Oct 21, 2009 | Dell Inspiron B120 Notebook
My laptop's screen is messing up
this happens when the backlight cable is lose
laptop sceen is an LCD which uses a ccfl backlight to light the screen
this backlight wire sometimes gets lose as it passes through the laptop hinges
get a proper technician to tighten the wire to to put a new one
Sep 29, 2009 | Toshiba Satellite M30 Notebook
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
Screen on Sony VAIO PCG-SRX99 needs to be tightened.
you will have to take the bezel front plate of the screen off and check to see if anything there has broken from the hinges. there are usually two-three screws holding the hinge to the screens back cover and two-three holding it in place on the base of the laptop. if all those are intact you will need to replace the hinges.
good luck
Apr 06, 2009 | Sony VAIO SRX99 Notebook
Screen swap out for a sony vaio vgn-fw235j
With the power disconnected. First off there are 4 rubbers on the screen bezel itself. Take those off and then unscrew the 4 screws.
Then take off the screen bezel itself, it will be held in by clips so you may have to use a flathead to pry it off.
Once you expose the screen, there might be one screw on each side holding in each screen hinge, if so that those screws out.
At this point there will be 4 screws holding the screen in on both the left and right side hinge.
Go ahead and take off the 4 screws on each side of the hinge and this will loosen the screen completely.
At this point go ahead and unseat the connector that goes to the inverter toward the bottom of the screen. Also unseat the connector that goes to the back of the lcd.
At this point you will have the old screen removed.
Now go ahead and screw in the screws on the left hinge and right hinge so the new screen will stay in place. Go ahead and hook up the connector to the inverter, hook up the connector to the back of the lcd. At this point go ahead and turn on the laptop and just verify that the screen works and that there is no defects such as lines in the screen or weird colors. If there is then you'll need another screen.
If you have the 2 screws, screw each one on each side of the hinges to keep the hinges in place.
Then go ahead and snap the front bezel in place, then go ahead and put the 4 screws in place and then the rubbers on and you'll have a working laptop with a new screen in place.
Mar 11, 2009 | Sony VAIO VGN-FZ230 FZ Series Notebook
Sony vaio vgn fw21l,loose hinge
I am a PC Technician, I also happen to own a Vaio with this cool but very fragile power button. It will be okay to leave it like that.I had the same issue and I repaired mine because I have experience tearing down laptops. The labor to get to that little plastic piece is extensive. If the situation arises I can explain to you how to do this, ill even have pictures as it is nearly impossible to find service manuals for new Vaios. But it will be fine if it is a little loose.
Feb 18, 2009 | Sony VAIO VGN-FW140E/W Laptop
Loose hinges
I met this problem almost all brands of laptops. Depending on how the hinges being built (return spring, embedded lock notch, etc.) Some are easy to adjust and some need more precise tightenings due to wear and tear of the lock notch. However you can buy hinges too at ebay just specify the brand and models as well as the LCD screen part no. replacement. Hope this gives you hint.
Best regards,
Feb 14, 2008 | Dell Inspiron 4100 Notebook
Screen hinge too loose
a the base of the screen you may see some scews that cover access panels, open them up and you can tighten the little nut that tensions the hinge. I had a laptop that was shaky and I tightened the hinges and it was OK after that.
Jan 24, 2008 | LG X-Note LM50 Notebook
Sony VAIO VGN-UX280P Notebook Logo
611 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
