Need operations manual for carver prh 2 "learning" remote control
2 Suggested Answers
  • 159 Answers
SOURCE: Describe your kenwood manual "ka
Hi, Yes it is safe to leave this connection unhooked. The system control is what the stereo uses to remote control a cassette deck,cd,turntable etc... using the amplifier separately should be o.k. I hope this helps, good luck and thanks for choosing FixYa-Prodzilla
Posted on Apr 20, 2011
How to find a manual for JVC LP21036-039
There isn't a standalone manual for this remote. It is not a programmable remote. It is the basic operation remote supplied with JVC VCR models:
HR-XVC27U Learn More HR-XVC29UJ Learn More HR-XVC37U Learn More
You could go download the manual for one of these VCR and read through the relevant sections. All they'll do though is tell you how the VCR operates from the remote.
Sep 08, 2014 | JVC LP21036-039 Remote Control...
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
How can I get my onkyo remote control (RC-693M) to control my Sony LCD tv?
Manual says: 1. While holding down the REMOTE MODE button for the mode in which you want to use the command, press the [ON] button. *** Hold both buttons down for 3-4 seconds *** 2. Press the button you want to learn the new command 3. Point the remote controllers at each other, about 2-6 inches apart, and then press and hold the button whose command you want to learn until the Remote indicator flashes. *** Hold them level with each other, 2-3 inches apart, and don't move them at ALL while you press the button on the old remote *** 4. To learn more commands, repeat steps 2 and 3. Press any REMOTE MODE button when you've finished. *** If the command was learned correctly, the remote indicator will flash *SLOWLY* twice - about a 1 second blink, and the red light will remain on. If the command was NOT learned correctly, it will blink twice *QUICKLY* - about .5 seconds, and the red light will go off. *** If the red light stays on, you're golden - keep going until you get to a button that flashes red quick and the light goes off. Some of the buttons I programmed took 6-7 tries in exactly the same position to learn.
Oct 09, 2012 | Onkyo TX-SR705 Receiver
My newly purchased home has a Beninca MS4 automatic gate opener but came with only one remote control (Liftmaster 371LM remote). I purchased two additional 371LM remotes online but do not know how to...
hi,
You have to oppen the motor control pannel. There will be circuit board inside it. In the circuit board you can see a Push button switch. It is the learn switch.
After powering ON press and release immediatly this learn switch. With in 30 seconds press and hold the button you wish to use until two click heard from the control board.
If you can sent me your email id through FixYa then i will sent the picture which shows the learn switch.
OK.
Aug 29, 2011 | Elite Sl 3000 Ul Sliding Gate Operator
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    My Onkyo DR90 DVD Remote Will Not Operate Components
    Your Onkyo DR90 DVD Receiver remote control does not have universal remote functions, and cannot be (easily) programmed to control a Panasonic DMR ES15. Your DR90 remote does have a limited learning function, but it is designed to learn the codes from your TV's remote to control the TV. Only the following buttons are programmable by the TV Learning function:
    I hope that helps.
    ______________________________________________
    Onkyo DR90 DVD Receiver User Manual Download.
    Apr 14, 2010 | Onkyo DR90
    How do u program Bush DFTA13HD STB TV buttons
    The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
    1. Press STUDY key until Red LED remains lit (for about 3 seconds)
    2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
    3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
    4. Now the Power key can turn on/off TV/s power
    5. Repeat settings of learning for the other keys
    You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
    Note:
    1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
    2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
    Jul 19, 2009 | Televison & Video
    Need codes that will operate my ONKYO BLUE RAY DV-BD606 player
    there is no sulution as far as codes are considered for blu rays. You have to do a manual learning mode for every button.you need to buy a learning remote this is where you point both remotes at each other and press each button to learn it. unfurtunately your sony remote does not have this funtion. i hope this clarifies your problem.
    Jan 10, 2009 | Sony RM-V302 Remote Control
    Cable ez 2.4ghz wireless catv sender
    I have a Cable EZ remote with the instructions o the back. See if this will help you (I wrote it below exactly as written on the remote):
    Remote Control Description
    How to set up the remote controller:
    For first time to set RF controller ID Code
    1. Press [SET] + [FUNCTION] together
    2. Key in your personal code (3 digits 000-253)
    3. Press [SET] again to finish
    For CATV sender learning the remote controller ID
    1. Plug the adapter into the CATV SENDER and wall outlet and the sender will power on automatically
    2. Press [SET] + [POWER] in 10 seconds to set CATV SENDER ID code. It will show your personal code on the screen.
    The remote has a label with the model number AWV351RC and an FCC ID of NGVAWV35XRC. Made in Taiwan.
    Hope this helps. I am missing the operating manual that came with the unit, so if anyone has a copy you can scan and post, it would be appreciated.
    Feb 08, 2008 | Televison & Video
    122 people viewed this question
     Grubhead
    Grubhead
